Short answer: 900-1000 full cycles.Does anybody here know how long approx. a Rad battery lasts?
I've had a RadCity for close to 1.5 years now but commute daily with it (yes, even in the snow) and have about 3200 miles on there battery.
In any event.... it's about cycles, not mileage.
This, and a few more were mentioned in my post, 5 posts above this one. You are welcomeIMHO, it's about a lot more than that. For starters you can add charge rates, discharge rates (e.g. do you pedal?, do you live in an area with a lot of big hills? Or, do you ride in PAS 1 only while pedaling full time?), battery age is a big factor, maybe % of your riding done in below freezing weather, and I'm sure a few more that aren't coming to mind at the moment.
Guilty as charged Alex. I did not read the entire string prior to replying. Obviously we're on the same page here.... -AlThis, and a few more were mentioned in my post, 5 posts above this one. You are welcome
@Browneye: I am curious, what battery manufacturer "guarantees" that it will last 5 years without serious capacity degradation.
2 thoughts. First, you might consider having your battery rebuilt be somebody that does them professionally. 2nd, what kind of temps are you riding in? Cold weather can have quite an impact on battery performance.
I charge the battery while I work a normal 8-10 hour day. Does RAD expect me to invest in a charger that cuts off at 80%? That doesn't seem right.Are you leaving the charger on for FULL charge cycles, not trying to follow the 80% thing for instance?
What is your final charge voltage(total)?
