Battery Pin and Hole (Erosion)
If I'm understanding correctly, you wanted the parts to hookup a second battery?
Not even close.
Nor I.
I wanted to mount the spare tray to my rack so I could carry a spare Rad supplied OEM battery that could be cold swapped on the road (NOT switched, the bike is still under warranty). I figured that if anything happened to the new battery, I didn't want Rad claiming that any warranty I had on it was void because I was carrying it around without it being mounted to a Rad approved/supplied thingy. So much for that idea. I asked about the cable/connector after seeing the first post in this thread, just to have as a spare, another delusion on my part.
Not even close.
FWIW, I have tried to get Rad to sell me a replacement battery tray (with socket, cable and connector) and they wont.
To clarify, my battery tray is not corroded (yet), and I have used dielectric grease and protective caps when the battery is off the bike from the beginning. I wanted the tray to be able to carry a spare Rad brand battery (IF they ever become available as spares again), I posted my experience/frustration in trying to obtain at least some the same parts the OP needs as an FYI.
Way off:rolleyes:
I am in Edmonton and I am having the same issue. Just wondering what you did for your repair? Thanks!
