Battery Cross ref
jangles
Where can I find a list of replacement type batteries for my bike ? It uses a 48v 10.4 ahr battery . It is marked Reention on the case and the number stamped on the battery is
Reention HC -48V10.4Ah-H-OW-YY-090464 . Any ideas ? TIA
If it's a Reention Dorado like this:
Then, there are lots of bikes that use that form factor in both 36 volt and 48 volt with varying amp-hour ratings. My Magnum Metro+ uses it with a 48 volt, 13 a-h. Juiced uses them. And others. You just kind of have to look around. Perhaps someone has put a list together.
I dont know which model it is . I included what is printed on the battery and even did a google search with no luck . I can get them through the bike manufacturer but like most of us would like a cheaper option if possible .
Edit: Is it possible to get one with more Ah cap or am I stuck with 10.4 ? TIA
Thats close but the battery display is not quite right . One would think that by doing a search with number that's stamped into the battery it would turn up the exact battery .
