I have searched the forum and found some guidance, but would appreciate concise answers to the following. This is my 1st e-bike (getting old now, so replacement costs do play a role). A 2023 Turbo Levo with a 700w battery. I have a solar installation with Li-ion batteries and wonder if the same rules apply.
1. I assume it has an overcharge function? Surely I cannot be expected to check the charge level overnight and disconnect when full? Assume I ride into the early evening and want to do so again early the next morning. Should I use a timer to be safe?
2. I understand the concept of DOD. With solar batteries, one would typically limit the discharge but it charges through the day to 100%. Here I read that it may be beneficial to not charge to full. This does not make sense to me. What is the best DOD? My solar batteries can run to 0%, but have always set to a recommended 10%. The latest app update limits it to 20%. Clearly, manufacturers want to guard themselves by playing it "safe".
3. What counts as a charge cycle? Can I charge from 50 or 80%, or must I wait and plan my rides so that it gets lower before I charge? The assumption is that the number of cycles is separate from the health of the battery, i.e., I can charge as much and whenever I want without worrying about cycles when generating health reports and possible claims.
Thank you for your attention and time!
