legsofbeer
So, reading various posts about hypermiling one's charging regime to milk the most lifetime range out of your battery, I have to wonder if the standard practice (with some vendors) of balance charging is sub-optimal. The instructed practice is to, approximately every 30 days, charge your battery fully, then leave the charger connected for another six hours so the BMS can balance out cells once the battery has reached a nominal voltage. But... we are advised to not charge the battery when it is hot off a ride or from outside ambient temp (reduces longevity). Yet charging heats the cells. So in that vein, would it not be better to charge the battery to whatever near nominal it will do, then disconnect the charger, let it cool, then reconnect and let it have the balancing sesh at a less damaging temperature?
I'm not claiming this would increase battery lifetime range, just thinking that if one is that into hypermiling battery lifetime that one would make a point of keeping the battery's charge within the 20-80% range, this might be another consideration.
