I bought the new Watt Wagon superbike (Ultimate Commuter Pro v2). Really excited about it, and October can't come soon enough.The Bafang designations are very confusing at best, but I think this is about right.
The bafang Ultra is also called the G510 and M620 it is just different names for the same thing a 1000watt nominal Mid Drive with torque sensing that can only be used in a dedicated frame.
The M600 is a lower powered smaller version of the ultra basicly.
The BBSHD is a 1000watt motor which you will work on a standard frame, does not have torque sensing.
The BBso2 is a 750watt version of the HD.
I think that is rightthe Ultra info certainly is.
What bike did you buy?
Yes, the new controller will be standard. I'm stoked!Nice you have the g510/m620/ultra then. Does that come with the upgraded controller that WWagons offer?
Regardless I am sure you will love it.
BBS02 and 01 were the first. Now BBS01B and BBS02B. BBSHD came later and has a lot of different parts. But share a harness and the same Higo connectors and accessories . BBSHD motors are often labeled 750w. 1000w is a programming change. 01B and 02B are 68-73mm. BBSHD Has several bottom bracket widths, 68-73mm, 100mm, and 120mm.The BBSHD is a 1000watt motor which you will work on a standard frame, does not have torque sensing.
No. They only share a harness. Speed sensor and the same HIGO connectors. A new BBSxx series motor could be easily plugged into and existing build. I’ve seen quite a few customers buy bare motors and reuse the rest of the components. I hope that helps.Interesting... are you saying that the BBSHD and 750w BBS02B have the same controller as well?
