Robert Jackson
New to E-biking and needed some recommendations for a 20 x 4
puncture proof type tire. Thanks in advance.
"Puncture proof" is a very high standard. My wheel barrow tire is puncture proof, but it's not a pneumatic tire. Bicycle tires are pneumatic to lighten the weight of the wheel and provide some shock absorbtion for the ride. As such, you can improve puncture resistance, but not achieve puncture proof performance.New to E-biking and needed some recommendations for a 20 x 4
Much appreciated!"Puncture proof" is a very high standard. My wheel barrow tire is puncture proof, but it's not a pneumatic tire. Bicycle tires are pneumatic to lighten the weight of the wheel and provide some shock absorbtion for the ride. As such, you can improve puncture resistance, but not achieve puncture proof performance.
Tubed tires can use products like Slime in the tubes to seal punctures. There are also plastic strip (thorn strips) and foam inserts that further improve puncture resistance. Some posts in other threads suggest thousands of miles between flats with these approaches.
Others convert to tubeless tires with a Slime product in the tire. This is used by many mountain bikers and come standard on some MTB models. They are highly puncture resistant, but require that the wheels be setup for tubeless use.
None of these approaches are puncture proof. I always carry a flat repair kit and a spare tube, just in case.
what size are your tires..I see that some tires doI also use Mr. Tuffy tire (thorn) liners with very good results. I combine these with Schwalbe Marathon Plus tires for 'near' puncture-proof performance, but I still carry that flat repair kit and spare tube 'cause #hit happens...
Where did you get extra thick inner tubes?Mr. Tuffy tire liners are the best I've used. Granted, nothing is 100% puncher proof but liners reduce the risk. My ebike came with Slime tubes and I got sprayed with neon green goo while putting air in the tires, so I took out the Slime tubes and put in extra thick inner tubes. Combined with my liners I should have fewer flats.
My ebike tires are 700x47.what size are your tires..I see that some tires do
nt come in 20 x 4
Thank you...what bike do you have?My ebike tires are 700x47.
Have you taken a look at thos thread; https://electricbikereview.com/forums/threads/bike-liner-recommendations-for-the-radmini.23704/ . Has some useful info on tire liners for fat tire bikes.
Puncture proofing is a tough ask with pneumaticsNew to E-biking and needed some recommendations for a 20 x 4
nt come in 20 x 4
