Ancheer 26" 36v 250w Controller help
Zenkouki
Hi everyone. I bought an Ancheer 26" MTB 36v 250w used. Ebike doesnt run. No power on twist throttle, no power on pedal assist. Ive hook up the throttle directly to hub and i get power so i bought a risunmotor controller but im stuck at the throttle cable. The throttle cable has 4 wires. Red black brown and blue. The blue splits off to what looks like a sensor in the pedals. Any ideas what the brown and the blue wire connect to on my controller connector? Controller throttle connector is red black and blue.
Thanks
Which risunmotor controller? (Link Removed - No Longer Exists) I believe I have a simialr unit, but from ebay. Did you buy the LCD display too? It's kind of crippled without it.
I'm thinking that a thumb throttle is like 10 dollars and a pedal sensor is 5 dollars. Buy new ones that fit the controller and chuck the old throttle. You also need a speed sensor if that's the same controller.
I have the 36/48v 15a one but it looks like some of the wires shorted too. I just bought another controller and throttle. Illhave to splice and solder most of the wires though.
Do you mind explaining this better? "I've hook a throttle directly to the hub and get power". The only thing that goes to the hub is the wires from the controller. Throttles connect to the controller.
Also, you melted wires on the first controller that you bought? Are the new pictures from the first or second controller.
