Aftermarket Suspension Forks ?
e-boy
Looking to upgrade the stock suspension fork on a 2020 Giant Explore e+4 .
I replaced the spring on the stock fork with a hard spring and it's an improvement but I'd like to try an air fork .
This is for pavement only riding so I think 50mm travel is enough .
Thinking of the RockShox Paragon Gold RL ; $260
Any others I should consider , and would like to know if any new fork models are coming to market this spring .
I wasn't happy with the stock air fork on my Pedego Platinum Interceptor so I replaced it with a Rockshox Gold A2 RL. I went from 80mm of travel on the old to 100 on the new. There was a noticeable improvement, even on smooth pavement. The swap was easy and took about 30 minutes.
You should be happy with the improved performance of the Paragon Gold RL. You'll need a good shock pump if you don't already have one. The trick is to set the proper pressure for weight and type of riding you do.
+1 on the Thudbuster. I use both the ST and LT versions.
