Is there such a thing as a flasher unit that I can wire into my E-bike headlight/tail light to create a strobe effect which is more easily seen than a steady light. My bikes are both 36 Volt - A Momentum Vida E+ and a Kalkhoff.
I have a Yamaha cross core with standard Yamaha 6v LED headlight. Like to know if I can modify headlight to blink? If so, can I make it switchable from blink/ steady. Thanks
You might want to test the voltage of the light directly as many systems run the light through the controller and drop the voltage. This will be especially true if the light is controlled through the display and it's buttons.
Then you can match a flasher relay to the voltage.
