Douglas Wever
I'm getting great range already. After posting that I scored a rare 14 ah battery instead of the standard 11.6 ah for my Pedego Ridge Rider (a 17ah will be released by Pedego this Fall), someone said to me that the battery will do even better after it is broken in at around ten charge cycles. What?
The last thing I want to do is resurrect an ageless debate over lithium ion 'conditioning' or priming. But if there is some conventional wisdom on this topic with ebikes I'd like to know it. Thanks.
[Lithium-ion is a very clean system that does not need additional priming once it leaves the factory, nor does it require the level of maintenance that nickel-based batteries do. Additional formatting makes little difference because the maximum capacity is available right from the beginning, (the exception may be a small capacity gain after a long storage). A full discharge does not improve the capacity once the battery has faded — a low capacity signals the end of life. A discharge/charge may calibrate a “smart” battery but this does little to improve the chemical battery. Instructions recommending charging a new Li-ion for 8 hours are written off as “old school,” a left-over from the old nickel battery days ((Link Removed - No Longer Exists)
