There are some YouTube videos on modifying the XP Lite. You may want to see a few of them before doing anything. You can also modify the factory settings to get quicker acceleration (how the power "comes on"). In the meantime just be prepared to be surprised on how peppy the XP Lite is. It accelerates just as fast as my old 500 watt XP 1.0 model did, albeit the XP 1.0 was much heavier. I think a couple of guys added a second front motor which may be the easier way to go. Also check with the Lectric tech guys as they have modded out hundreds of these units as it's a very popular model to do that. Having said all this...just remember the XP Lite has a SMALL battery so anything you do to add or increase power will kill that small battery quicker. Your range will certainly suffer...but if that doesn't matter to you...Mine hasn't even arrived yet, and I'm already looking into the possibility of upgrading it.
And yes, I do recognize that depending on what I do, I might have to also replace the controller, computer, etc.
The controller and motor are designed to work together..so good luck having Lectric trouble shoot any potential problems. I would run all this by them ASAP before you do anything. They will tell you exactly what you are facing. Should they tell you something that you don't want to hear... then send the bike back and get something more suitable.Here's that video showing the upgrade of a RadPower bike by just swapping out the motor inside the existing hub.
I would run all this by them ASAP before you do anything. ... Should they tell you something that you don't want to hear... then send the bike back and get something more suitable.
