Honestly? You can buy a good hardtail non-electric MTB for the money.For these bikes I prefer to be in $2000 range, any suggestions?
I meant a $2000 e-MTB was crapbasic entry level eMTB for $2000.
I won’t be doing any crazy technical riding-just some off road trails, should have been more specific. Hoping to get recommendations for decent fat tire bike in $2000 range. I have only ridden my Stromers for over ten years, have no experience with others. Thanks for responses!Any steep hill climbing, long down hill runs, technical riding, or mostly fun rides on level off road riding on improved trail or single track?
You might be limited to rear hub fat tire ebikes in the +/- $2000 range. The average specs for those types of ebikes are 65-90lbs, hardtail (no rear suspension), 7-9 gear range (limited hill climbing gears), 750w & 75-100Nm of tq, could be a mix of hydraulic vs cable 180mm brakes, avg chance of spring vs hydraulic front fork, probably a Class II with throttle with 20 mph speed, and a mix of cadence vs tq PAS sensors depending on the brand.
It is like @Stefan Mikes is saying of you can get a very good regular fat tire MTB or basic entry level eMTB for $2000.
Bee Cool PathFinder ST | $1199 | ||||||||||
Rattan Pathfinder ST | $1249 | ||||||||||
Lectric X Peak ST | $1299 | ||||||||||
ET Cycle T720 ST | $1299 | ||||||||||
Go Trax Tundra ST | $1399 | ||||||||||
Velotric Nomad 1 ST | $1399 | ||||||||||
Mooncool MC 3 AWD ST | $1399 | ||||||||||
Heybike Explore ST | $1399 | ||||||||||
Himiway Zebra All terrain ST | $1499 | ||||||||||
Bandit X Trail Urban ST | $1499 | ||||||||||
Freesky Wildcat Pro ST | $1549 | ||||||||||
Senada Herald All Terrain ST | $1579 | ||||||||||
FD Freedare Eden ST | $1599 | ||||||||||
Rad Rover 6 Plus ST | $1599 | ||||||||||
Haoqui Antelope Pro ST | $1599 | ||||||||||
Haoqui Eagel Long Range ST | $1649 | ||||||||||
Velowave Rover ST | $1699 | ||||||||||
Vetanya Alligator ST | $1699 | ||||||||||
Magicycle Ocelet Pro ST | $1699 | ||||||||||
Coffman's Ridgeline ST | $1699 | ||||||||||
Vtuvia Raindeer ST | $1799 | ||||||||||
Denago Fat Tire Bike ST | $1799 | ||||||||||
Aventon Adventure 2 ST | $1799 | ||||||||||
Velowave Ranger 2.0 ST | $1799 | ||||||||||
AIMI Big Sur ST | $1799 | ||||||||||
Ride 1 UP Rift ST | $1895 | ||||||||||
Hovsco HovAlpha ST | $1999 | ||||||||||
Velowave Pony Compact ST | $1899 | ||||||||||
M2S All terrain Scout ST | $1999 | ||||||||||
Velowave Grace ST | $2000 | ||||||||||
ET Cycle T1000 ST | $2099 | ||||||||||
Magnum Nomad ST | $2199 | ||||||||||
M2S All terrain ST | $2199 | ||||||||||
Mokwheel Basalt ST | $2199 | ||||||||||
Troxus Explorer ST | $2299 | ||||||||||
Stalker Forester ST | $2325 | ||||||||||
Ventanya Kodiak ST | $2399 | ||||||||||
HJM New Toury ST | $2399 | ||||||||||
Juiced Rip Current S ST | #2399 | ||||||||||
Magicycle Deer ST | $2499 | ||||||||||
Juggernaut Hub Duo ST | $2499 | ||||||||||
Excell Camo 26 ST | $2599 | ||||||||||
QuietKat Villager ST | $2799 | ||||||||||
Cyrusher Trax All Terrain ST | $2799 | ||||||||||
Predator Sabre ST $2875 | |||||||||||
Pedego Trail Tracker ST $2995 |
If you are used to Stromer's level of quality/engineering you will have to dip down WAY below that to reach a $2000 price point, and part of that descent will be taking on the compromise of a hub motor, which will give a dramatic performance degradation on trails in hill country. So dramatic you could find the bike unusable at times....
All of these fatties are mid drive motors, which is what you want.
What's the fat vs. plus cutoff? Other differences?But since fat tires have largely been displaced by plus sized tires (similar benefits with fewer consequences) it has cut back the availability of manufactured fatties.
Yep, fully agree. There are fat bikes and then, there are high tiered fat bikes. And the good ones seemed to have stopped production or just flat out left our US market as Haibke did (they even discontinued the fat ebike from their german catalog).If you are used to Stromer's level of quality/engineering you will have to dip down WAY below that to reach a $2000 price point, and part of that descent will be taking on the compromise of a hub motor, which will give a dramatic performance degradation on trails in hill country. So dramatic you could find the bike unusable at times.
The used Haibike would be ideal. Just for starters finding a quality ebike that is fat is more difficult than it once was, and it was never easy. I ended up building most of mine frame-up as a result of that. But since fat tires have largely been displaced by plus sized tires (similar benefits with fewer consequences) it has cut back the availability of manufactured fatties.
If I could take a swing at your questions.....What's the fat vs. plus cutoff? Other differences?
Somewhat off-topuc, but given your experience with sandy beach riding, what do you see as the minimum tire width for loose, dry sand? (My 2.3" hydrid tires are fine in damp sand — the kind available within a hour or so of low tide — but worthless in the loose, dry stuff.)
I was waiting for some response to the OP initial post before I responded.I meant a $2000 e-MTB was crap
A good air-fork alone starts from $1000.
A full suspension pedal MTB is well over $3000, no motor, battery or controller...
The fat phase in ebikes seems far from over here in coastal north San Diego County, where many seem to function mainly as cruisers, posing platforms, surfboard carriers, and schoolkid transporters. They seem to be heavily favored by renting tourists as well.With the fat phase over there could be some good deals out there on five-year-old bikes that have only be ridden a few miles.
I had ridden road-bikes, hybrids, gravels all my life and then a friend gave me an old Walmart-type fat bike (Iron horse). I was skeptical but fell in love even though I only rode it on road and didn't do any jumps or use it on trails until a long time later. Then I did some long distance rides to test my crazy idea of bikepacking on a fat bike and then gave away my other bikes. I started bikepacking with my fat bike in Colombia some 6-months ago and have loved every moment of my time with it as it's well suited for every terrain we have encountered. It also helps me make friends of strangers as people are curious if I have a motor, why I have tires bigger than those of some motorcycles and jus Why?On craigslist right now, I see a lightly used Haibike FatSix for under 2 grand, sized large. There is also ebay and facebook marketplace.
I personally would have no issue whatsoever, purchasing a used Haibike FatSix or Full FatSix as I know it was the top tier fat tired E-mtb of it's time. I say this from personal experience, having my Full FatSix since early 2017. Not one issue with the Yamaha drive system nor the battery or charger.
The early FatSix's were Bosch powered. The later ones, Yamaha powered. All had premium brakes, shocks and derailleur systems. The same also applies to a used Bulls Monster (Bosch powered) in both hard tail and full suspension and the Felt Outfitter (Bosch powered).
Go to the video reviews on this site and search out reviews of the FatSix, the Full FatSix and the Outfitter. I seem to recall Court Rye did a review of the Bulls Fat E-bikes. And then begin your search. Oh, I believe there is a later model Haibike FatSix (Yamaha powered) in the PinkBike want ads section. Quiet Kat has their populaity with the hunters, but it will require searching on the used bike aftermarket to find something in your price range. Look for the Quiet Kats with the mid drive motor. I believe they are Bafang motors, which bears more investigation on your part.
I cannot nor will not recommend any other new fatbike with a rear hubdrive 신용카드 현금화. They are heavy and made of cheap-o components, unlike your Stromers.
Haibike Full FatSix......
