K1eBikes
 - Europe
Dear Bafang fans
Would you like to set or tune motor controller parameters? K1 Flash is compatible with all Bafang CAN bus motors (5 pin connector with "house" shape).
Also can download motor firmware for M500, M510 and M600 motors and run Calibration.
Simple as 1, 2 ,3 ...
1. Insert included SD card (with set of firmwares - cca 50 firmwares)
2. Power up K1 Flash (over USB-C cable from your mobile, power bank, charger ...)
3. Connect to your CAN motor - steady green LED light means all set and you can unplug device
In a minute your motor is flashed and parameters set according setup text file on SD card.
More info, pictures, video and ordering info at:
K1 Flash page
Tested on M500, M600 rev.A and B, M510 FC1.0 and FC2.x, M620, M560,M820, M420, M300
Speed unlock, circumference, wheel supported by all Bafang CAN motors, including CAN hub motors.
K1 Flash Lite starting from 110 Eur including shipping in EU.
