EVO 27.5 Lite charger
Bruvvertr2
United Kingdom
Hi all
have a Easymotion Evo 27.5 Lite without a charger.
Battery not been charged for over 2 yrs.
questions....can i purchase a new charger?
is it worth it with the battery being dead for that time?
loved the bike when it was going
thanks all
As for the battery being dead, the BH batteries have a deep sleep mode that happens when it gets too low or the bike is not used for a few months, in that case you have to press the battery level button on the bottom side of the battery a few times to wake it up. Don't do it if you don't have a charger, as this will just reduce the charge level further. If the battery had half or more charge when it was left in storage, there's a good chance it'll be just fine.
As an emergency refill I would buy a generic 42V (36V) charger, find out the + and - leads of the battery and the charger, and jerry rig some way of connecting the charger to the correct terminals on the battery, and it should start charging.
The way I did it was to get a generic charger, cut its output leads at the very end and used a plastic screw terminal block (white sugarcube thing) to connect the stripped wires to 1.5mm2 single-core electrical wire, and stick the other ends into the female receptors of the direct-to-battery pigtail adapter that comes with the BH chargers.
About a replacement charger, I posted in your other thread, but here it is again:
The BH Evo 36V charger (above) output lead only has two wires soldered onto the board (+ and -), so I suppose it has no "communication" with the battery. The sticker on the back is incorrect, as there is no NTC-thermistor either (meaning heat sensor). The BMS on the battery merely opens the circuit when it's had enough juice, at around 41,8V in my case.
The thing then to look out for is that the generic charger is meant for a wide range of 42V (36V) e-bikes, and doesn't go too far above the 42V before cutting off even if the BMS fails to cut it.
My original 36V BH charger died, so I ordered an official BH replacement charger from Doctibike (France), and also used the old dead charger's lead to solder a female barrel connector onto it, that came with a generic charger kit that had swappable adapters for various e-bikes. It was from a local big chain store that sells it to use on their e-bikes and others. I've been using the generic at work and the official charger at home for a few months now no problem. The replacement BH charger was 160 eur with shpping, and the generic charger is 55e with shipping.
My local electronics repair shop did the soldering and testing, so it's got proper insulation and strain relief etc.
Generic "GZR 4-in-1" with BH Singatron 3-pin plug (and battery adapter pigtail) soldered onto a barrel connector (just skip the barrel connector and solder straight to the output of the generic charger, as the barrel connector can cause some heat lossess even at ~2A):
Official BH replacement from Doctibike:
Official BH replacement from Doctibike (the output "36V" is wrong, should be 42V since 36V would only get you to half full battery, but now the NTC is ignored which is correct):
BH old official charger output lead connector, only + and - are connected:
BH old charger circuit board underside:
