500c brake sensor indicator not working
Foxhound68
Canada
I just recieved my 500c display and have brake sensors installed and functioning 100% but the display ! Icon doesn't light up when I use the brakes like it should. Any advice on what could be going wrong or is my 500c faulty ? The sensors are cutting off the motor correctly! Everything else on the display as far as I see is working
There's no setting or adjustment for this so if the controller is shutting down the motor with a brake pull, it should also be sending the info to the display.
My vote, faulty display.
There's no setting or adjustment for this so if the controller is shutting down the motor with a break pull, it should also be sending the info to the display.
I've contacted golden motors about it will report back what they say.the brake sensors cut the motor perfect I even tried unplugging the sensors and replugging them in to see if that made the display work but no luck
