4th Gen CCS will be available with 52V battery
Just found the pinout document on Juiced's website. I've attached it. Looks like the middle pins aren't actually used. That would make the soldering job easier if you choose to make your own.
  • 4+Pin+XLR+pin+out+Charger+Cable.pdf
Fran wher did you find this document for the 4 pin? I need to find one for the 3 pin. I am obviously going to have to make a connector for the 3 pin XLR for a secondary charger. Right now I am thinking I will get the Luna Cycle 52V mini charger. It has a dial that allows charging to 80%, 90%, or 100%, and uses a 2.5 A charge rate. It costs a bit more than a simple 52V charger, but with the ability to set it to 80% and forget it, seems worth while. I will have to make an XT60 female to XLR male connector. I just want to make sure I connect positive and negative to the correct sides. Here's a link to the Luna charger, if anyone has any feedback regarding this I'd appreciate it. Thanks. https://lunacycle.com/52v-3amp-luna-mini-charger/
Nice idea but I've read high return rates. You can also use a multimeter and a timer to get to the same results.
