Grantdbiff
Hello all,
I bought a 48 volt 1000 watt motor online and am trying to test it out with some DC power supplies. The power supplies are limited to 24 volts and 3 amps. I have them hooked up in series so that I have a 48 volt supply. I know that this means I only have 3 amps and thus my max power with this setup is 144 watts. So here is my question.
Is this not enough power to turn the motor on? The lights on the throttle are turning on; however, my multimeter does not show any voltage on over lines going to the motor. Is this because the controller is using too much power and there is not enough left for the motor?
If that is the case how can I find out what the bare minimum voltage and amperage are to get this thing spinning? I just want to see if it even works.
Thanks,
Grant
Thanks,
Grant
