tomjasz
- USA
- City
- Minnesnowta
Not much info... but the chainring upgrade is welcomed.
Not liking the new mounting, looks like s*it to me. Mines holding tight so I'd probably choose to leave off the extra support clamp
Then for sure you shall be known as Santo BafangoI should be good until I take the dirt nap.
Believe me, we know and are frustrated by Bafang Corp's support.no one is noting is the motors are now CAN bus which means they have cut everyone off from the settings interface.
I totally agree.just yuck in every way, i hate it. i had not planned on it but looks like i will be purchasing an old school BBSHD before they vanish.
A dealer needs a code to access. I’m thinking we may be pooched as end users.if ever...
Thomas-What a nightmare! Bafang has never liked the fact that programming can be done by users. It looks like they have responded by only having dealers able to use the BESST programming. We could work offline but now a code is needed to use the software. Dealers are scrambling to find a workaround.
hosts.txt probably, it's a sensitive file that is frequently checked and corrected.We found it no longer works off our hard drive. I’m apparently missing something. Thank you!
Can you post a screen shot of the available parameters that can be adjusted?Well, well, well will wonders never cease, someone read the m500/m600 thread, at least partially and superficially.
CANBUS is programmable.
There is 2 methods, only one is fully operable.
The one they are struggling with is the penhoff type you are all used to, they're struggling to decipher the hexidecimal, the codes used to communicate with the motor.
The one that works is a local BESST server. Local means you have a version of bafangs BESST interface that lives on your hard drive. When BESST communicates with your PC it is subjected to a 'MITM', 'Man In The Middle' attack which redirects it from communicating for eg with server.bafang.com to communicating with your local version on 192.168.*.* whatever address your server is at (192.168.2.1 likely) this is done through changing the hosts file on your computer to believe 192.168.*.* is bafang. The password element is taken care of in the localised files you have.
I told you this months ago and provided the scripts and i'm the pariah?
