Battery Issue
lmansted
I purchased a Double Peak I/O and the battery will not charge. I just keep getting an error on the battery charger. Has anybody had a similar issue? In a related note, has anybody found a way to charge the battery off the bike?
Hi. Are you connecting the charger to the bike correctly? On the bike there is a very tiny notch in the receptacle through which the
corresponding piece from the charger side slides; after which you tighten the connection "ring" by turning it clockwise. If this isn't what's
causing your problem, contact Haromtb at 800-289-4276. Also ask them about getting an adaptor to be able to charge the battery off the
bike. Hope this helps.
How was the response from Haro? Did they resolve your problem? Easy to work with?
