New Battery on a A2B Alva+?
Hello everyone,
I have an Alva + and need to replace the battery. Its more than 6 year old. Can I replace it with the battery from the current models (shima or Speed)? Will it be a problem for the motor or controller?
Originally it came with a 36v 13.2ah battery. The ones found i nthe newer models have 36V, 17 Ah.
Thanks!
Ummm....I purchased a NIB A2B '13 Shima, and then purchased a '19 A2B "Speed" battery & it works great. The Alva+/Shima uses the same battery. Yes, the higher Ah battery, though more expensive, especially when upgrading a rebuilt battery will work.
How do you like the Alva+? It's 20mph w/throttle & then 24'ish mph with PAS, right?
I was given an a2b alpha plus eboke but it has no battery and I can't find a replacement anyvsuggestions
Where did you find a battery
