AHicks
- USA
- City
- Snow Bird - Summer S.E. Michigan, Winter Gulf Coast North Central Fl.
We bought this Sport with the idea of using it as an affordable base for a comfortable city bike. Not looking for anything flashy. Comfort is the primary goal. We've had it for a couple of weeks now. Parts have been dribbling in to the point where it was time to start work. So here we are -
An update on the project bike - '21 Espin Sport
The Schwalbe Super Moto-X (balloon) tires are now installed (27.5x2.4"). They have plenty of room but I wouldn't want to go much bigger. Mounted on the 32mm rims they look pretty good. Initial ride indicating I may be able to drop the tire pressures 5psi. I took a guess at 35 front and 40 in the back, and they're still pretty stiff.
Thudbuster LT seat post with HD elastonomer (for fat guys) installed with my favorite C9 seat. The one with the Lycra covering. Just seems to work for me.
Handlebars changed to something like a mustache type with 3" rise built in, and Velo grips for a locked on comfortable feel. Pulled back style for wrist comfort.
Thumb type throttle installed on the RH side. That's a pretty tight fit. Unless you're stubborn and demand it, not sure I'd recommend that project. It ended up working great, but it was a PIA. Best left for those with a lot of patience....
I did change the shifter to one with an indicator - that reads backwards - but at least I can see where I'm at. Works awesome, but something we'll likely revisit sooner than later.
And the display/controller issue. I spent a lot of time screwing with it, looking for a magic combination that worked just the way I wanted it to - but in the end couldn't find one.
The 2 biggest issues are (no particular order)
1. The display washes out pretty much completely in direct sunlight. Now I understand it isn't too unusual with color displays, but this is the worst of the 3 I have (Bafang, KT and this Espin). Secondary issue, a big deal here, but many others won't care I'm sure, is the tiny power indicator (watt meter). It's impossible to read in direct sunlight, and not easy even under overcast conditions
2. Power runs on for a good 10' when you stop pedaling. That's complete nonsense, and there's no excuse for it in today's world. Espin advised me to "just tap the brake". Geez, thanks for that advice.....
After that, there is the fact it's speed based. Nothing terrible though. I think it uses cadence speed in the algorithm, which is kinda weird. For instance, in PAS 1, and lets say 2nd or 3rd gear, you can see 300 watts in use as soon as the pedals start moving at 6-7 mph. Exact same scenario, only with the bike in 4th or 5th gear (so you are pedaling WAY slower) there will likely be less than 100 watts in use. That's rideable and there's no big surge every time you start pedaling like there would be if the bike were in 2nd or 3rd gear. Different, but you should be able to get used to that.
So after checking around, we're going with another KT set up (waterproof KT 22a w/LCD 3). And this time, it's not even going to have a color display. The LCD display is MUCH easier to see in direct sunlight - at half the cost of the color. Please note!! This would not be a poject I'd recommend for a DIY rookie. There are NO Instructions included, and support will be sketchy at best. That said, if you have some extra patience, can solder a new connector on if necessary, and have a good working knowledge of electrical ideas (not necessarily electronic ideas) these mods are not TOO bad. -Al
Tires- https://www.amazon.com/dp/B00OJXA1FS?psc=1&ref=ppx_yo2_dt_b_product_details
Thudbuster LT -https://www.amazon.com/dp/B088Y7DXWX?psc=1&ref=ppx_yo2_dt_b_product_details
HD (fat butt) elastomer for Thudbuster - https://www.amazon.com/dp/B08BW5589F?psc=1&ref=ppx_yo2_dt_b_product_details
Seat Cloud 9 - https://www.amazon.com/Cloud-9-Crui...&keywords=cloud+9+seats&qid=1623546022&sr=8-5
Handlebars - https://www.amazon.com/dp/B08QZ889WG?psc=1&ref=ppx_yo2_dt_b_product_details
Thumb Throttle - https://www.amazon.com/dp/B08CKBV1M3?psc=1&ref=ppx_yo2_dt_b_product_details
KT 22a Controller - https://www.amazon.com/gp/product/B08Q4B915H/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
LCD 3 Display - https://www.amazon.com/gp/product/B089W7Y46C/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
To be continued....
To be continued....
