fillerupmac
After four brief (<3 miles) rides...
Build:
- Frame: I ordered the large frame, after discussion with Roshan. I am 6' 2", with 30 inch inseam. Tall, but short legs. If I raise the seat to extend my legs properly when pedaling, I'm on tippy toes when I stop.
- 26X4.8 tires - BIG tires! May be my imagination, but smoother ride, fewer bumps. Had to deflate the front wheel to install, to get past the brake.
- Gears: I count 10 gear wheels on my "9 speed" . Shifting appears to be dialed in pretty good so far. No initial adjustment needed.
- Shifter - not like the shifter on my Rover, but I like this much better - easy thumb or second finger triggers.
- Handlebar - mounted quickly, comfortable position.
- Grips - didn't expect ergonomic grips - very nice, but I also had purchased a Mirrycyle mirror that mounts in the end of the handlebar. Previously, I used a mirror that mounted on the handlebar (inbound from the grip), and my body blocks the view. I plan to try to customize the grip soon, to possibly mount the Mirrycycle mirror in the end of the handlebar.
LCD controller - I was looking forward to a color controller, but it could stand to be a little brighter! More functions than the controller on the Rover, including a CLOCK! But the text is hard to read, at least with my 70 year old eyes. Had to hunt down a manual on line for the DPC-18 controller, so I could figure out how to change from metric to Imperial (as they call it). See here (Link Removed - No Longer Exists)
- Seat: Pretty hard - may not like it on a long trip. May have to get another Cloud 9!
If I did not mention something (for example: pedals) then it was pretty typical - neither good nor bad, and worked first time. Many many Kudos to the crew at Biktrix!!
Riding: Smooth, powerful, the middrive motor makes the bike handle like a dream so far. I still work in my store during the day/week, so I haven't had a chance for an extended ride yet. But I like what I've seen so far!
In summary - if I had done a couple of these, I feel you could roll this out of the box, take 15 minutes to mount the front wheel and handlebar. and happily ride off into the sunset!! What a great bike!
Here's initial photos: Click for large image
Al Schlafli
Build:
Al Schlafli
