Review of Junto Gen1 Ebike, an Interesting All Around Bike
Ann M.
Named after the historic Junto Club started by Benjamin Franklin a couple of hundred years ago, the Junto Gen1 electric bike is an incredibly well thought out design at a very reasonable price, $2,200. Designed for all around city riding, the bottom bracket, headset & hub bearings are all sealed, so you're not going to get road grit & water out of the bearings. Junto chose a very high torque 350 watt geared Bafang motor and a larger 48V 11ah lithium pack for better range & overall lighter weight. With the weight balanced a little to the front, you have more positive steering and quicker reaction, much like a better made mountain bike and offsetting the weight of the rear hub motor. Note too the reinforced eyelets on these wheels; a much stronger build. And with Junto's focus on just one model right now, the bike is built to be upgraded without a lot of problems. I'm looking forward to an opportunity to test one of these bikes soon! Check out Court's review for all the details.
https://electricbikereview.com/junto/... The Junto Gen 1 is a sporty, responsive, urban style electric bike with 29er wheels and higher volume tires that create stability and add comfort, available in three frame sizes and two color options. All-aluminum frame is purpose built for ebike applications with a suspension-corrected geometry so you can add a 100 mm suspension fork aftermarket, tapered head tube and 15 mm thru axle. Excellent 11-speed Shimano SLX drivetrain with Shadow Plus clutch, wider 25 mm rims with reinforcement eyelets and thicker 13 gauge spokes in the rear to support the 350 watt geared motor. Simple display only shows battery level and 1-5 assist, the blue LED's can be annoyingly bright in dark ride conditions, nice locking ergonomic grips, gel saddle, and alloy platform pedals, hydraulic 180 mm disc brakes with motor inhibitors.
