Rumors, from the inside
Yes, they are the last. Recently, Bosch has invented the hub-drive motor.
Surely you have ridden for 20,800 miles on that e-bike to draw your opinion.
It's not an opinion, the seatpost isn't in far enough. Does that mean the bike explodes? Nope, certainly does not, it's just not installed properly.
Bosch didn't invent THE hub motor and I made no such argument. They're late to the hub motor game but I suspect it's going to be a pretty dialed in product since they're using the same battery and display/control systems they've had in place since releasing Smartsystem.
You have watched the e-bike on the first day of the ownership and made a conclusion. You are not aware of my body build either. Pathetic, to say the least.
Your point was Specialized didn't care about its riders. Wrong. It is still the same Specialized e-bike 7 years post the purchase, with all the Specialized care given to it. If you claim otherwise, you must have been a successful Specialized dealer for years, and know all the trade secrets.
This Specialized e-bike is now 5 years old and has never needed any Specialized assistance except some software updates. Over 20,000 km ridden so far.
Pathetic? Stefan I don't think you understand what I'm saying. Seatposts have a minimum insertion line set by the brand to avoid catastrophic failure of the seatpost. Your seatpost is clearly above the line for minimum insertion. Doesn't mean it won't work for your particular use case, but it's not correct according to the manufacture specs.
I also said nothing to the fact about Specialized and "it's riders" care or otherwise. Perhaps something is lost in translation...
It was the first morning with that e-bike, and everything was set up properly soon. I'm surprised you draw any conclusions after having seen a single photo.
Personally I like knowing I'm selling a product that will provide the customer years of service and the brand will support that product well beyond the warranty period.
I doubt PON.bike would overlive Specialized. Specialized does care, and the user is paying a premium for that.
I mentioned in a different thread that on a Marin bike I set the saddle height to the minimum insertion line from the mfg. And it still broke the top of the frame. On that mid-step bike the bottom of the seatpost was not below the top tube when set at the minimum insertion line. The dealer documented it and a few days later they gave me a new frame. The line was just wrong for that bike. I also purchased a longer seatpost that had thicker walls. I know their head of tech service and they have a warehouse in my town that is filled with warranty life time replacement frames.
It's not a hard conclusion to draw that the seatpost isn't in far enough.
Have I run seatposts above the min insert line? Sure, but I knew full well that I might destroy something or hurt myself.
Would I endorse it on a customer's bike? Absolutely not, it's a clear violation of what the manufacure suggests thus voiding the part against warranty claim and can cause the rider serious harm (most importantly).
Do they raise the seat back up above the line? Sure do, or best case, they buy a longer seatpost and we put the issue to bed.
I think you're confusing a brand "caring" for what Specialized does when one of their lifetime frames has a failure. They don't send a new frame, they send an entire bicycle. That's how they support, or in your words "care," about the client. So, that means, if, you have an issue with the frame, you'd get a complete new bike. At least here in North America you would. Trek does the same thing when a bike is clearly out of production.
They sent the dealer a New Old Stock frameset (including a new suspension fork and a matching front wheel) and then the dealer rebuilt the e-bike from the scratch.
This is not the minimum insertion marker Brendon. It is just a scratch. (The minimum insertion marker is engraved at the rear of the seat-post, not around it), I hope you are more competent with the e-bikes of your customers.
View attachment 217034View attachment 217035
When did that replacement happen? Here in the US that generation of Vado and Como are long gone and so are the replacement frames so if you have an issue with your frame, it's new bike time. I've warrantied more than a few Specialized frames and that's the process I went through for my clients.
Fair enough, at a glance I thought it was a min insertion line, my bad. They're not always at the rear of the seatpost either FWIW. No need for the personal attack Stefan.
The Mfg. Date indicates the replacement frame was 5 years old when it reached the Specialized dealer.
Huh, well good for them. My experience as a dealer here in the US has yielded mostly different results both with Specialized as well as other well known brands.
The common theme was all of the brands took care of the client as best they could, which is nice to see because the dealer usually gets the short end of the stick and ends up eating many costs.
the wonderful world "warranty upgrade", at some brands where I worked in the service department we had to exchange frame for the new platform's frames after the warranty frames where gone... so in those cases it was either get the dealer/consumer to buy some new parts (seatposts, BB+crankset etc...) or get the consumer a warranty upgrade (new bike on highest margin minus the "cost" of a new frame) which in most cases was the best option.
Was also a fun scheme with roadbike forks.... at a brand where I worked we had limited stock of forks, after roughly a year (or 2 in luck) there where just solid black versions available... always a fun discussion with dealers and consumers.
And yes, the dealers margin on bikes is way higher than what a brand has, so that's also a part of the cost discussion.
Any owner with a rim brake bike and "lifetime warranty" rarely gets a replacement frame these days. It's basically a discount off of a modern bike, because you can't economically swap components.
Pinarello had a paint issue with painted aero seatposts in a couple of colors. Replacement from Italy took months, but the customer was offered a black one quickly. We ended up ordering the painted warranty replacement and buying the black one as a "shop loaner". It ended up being used on two bikes.
Kinda, but not exactly. An SL 1 is my main ride now, and I'm very, very happy with it.
The Creo 2 Carbon Comp I also considered was significantly lighter and had the 1.2SL motor with ~50% more power and torque from the same battery. The Creo also had a dropper seat post and a more advanced Future Shock stem.
In late 2024, that Creo 2 was at the very top of my budget at ~20% more than the SL 1. Problem was, the necessary flat-bar conversion would have put it out of my price range.
I agree that a Creo 2 Flat Bar conversion at an LBS could be very expensive but doing it yourself isn’t too difficult and can be done at what I think is a reasonable cost. I converted my Creo 2 to Flat Bar (which is what the Vado SL 2 should have been …)
SRAM G2 RS levers (which are DOT fluid so no need to change lines or calipers) - £110
Specialized Vado Flat Bar – (very lucky on eBay !!) - £15
SRAM AXS Pod Rocker - £120
Pair of Grips - £20
Specialized Comp Multi Stem £20
The only LBS cost was a Brake Bleed - £30.
Total £315 which I thought was ok. I could have also covered most of the cost, if not all, by selling the original Drop Bar, SRAM Levers and Stem but decided to keep them so the bike can be converted back if needed. Really pleased with the bike now
Pair of Grips - £20
Well done! Would love to see photos of your flat-bar Creo 2. Is it set up more for gravel or pavement?
Hi, I use it primarily on tarmac. Couple of photos attached.
I also forgot that I needed the 'power switch' which I got for £55, so slightly more than I stated.
