Anyone get one of these yet? Review? (Turbo Vado 3 X 6.0)
Here you go. Cheaper than half the price.
Or
That TL at £3,199 is remarkable value for what you get for the cash - and universally reviewed.
That was my point, you’re paying upfront for 2 to 3 motors and god knows what else. The best warranty you can have is the one you never need. :cool:
Two+ complete bikes is probably accurate.
Send me your Specialised wheel and I’ll test the hub behind a 60v Bafang Ultra to see how it fairs after 4,000 km, including some comps. :cool:
He wouldn't know anything about this as he's limited to 1 Donkey Power.
Which is fortuitous as that also seems to be his IQ 🙃
One good thing about wireless shifting is that your personal assistant 10 meters away can shift for you. On the downside, there is none, as we all know complex systems are not hackable.
Not a rear hub, mid drive, auto shift, etc.
I mentioned Juggernaut. He rides in gravel and XC races on a powerful Chinese Frey with a Bafang mid-drive. Recently, he destroyed his rear hub by the excessive power. He didn't have a Specialized warranty though.
I'm afraid the Amflow M2S would do the same in the Boost mode.
“Everyone“ is buying bikes with the Chinese made Avinox motor/battery ecosystem these days anyway.
My big Vado was rebuilt from the scratch and upgraded post warranty, as the "lifetime frameset warranty". Before that, the same Vado was upgraded to newer electronics, free of charge. It included a $560 powerful lighting required by law for S-Pedelec.
My Vado SL 1 has never broken. I was getting free service by Specialized though.
Stock rear hubs do take a dump when powered much over 100 Nm, plus the rider's input. They need to be replaced with better versions such as Onyx or White Industries. A heavy rider is more likely to experience this, or someone who does jackrabbit starts from a dead stop.
A typical Toyota Tacoma, or with an additional 'Ma,' a Taco-Mama, is good for at least 300,000 miles. The things that go beep, flash, network, and razzle dazzle like Vegas do not help with that. It is the underlying structure that counts. In the same way a good bike does not need to pair with a phone or use wireless. Auto-shifting is a joke and only for those who do not know how to master, ride atop, a bicycle. If you cannot change the stem or handlebar or do real programing, those are red flags to stay away. So is 'download the app.' That most often means that your bike can be remotely downgraded, as happened in Canada.
What a pain in the arse. Who wants to be taking their bike to shop to get fixed all the time, warranty or no warranty. Having a Specialized warranty would have left me in the same predicament……out of the race. I mean come on, numerous motor replacements are common. They’re almost like a wear item.
You’re also paying a handsome premium for your warranty. I am not. I have the ultimate freedom of choosing the replacement components. You do not. Who is in front financially and with component choice?
Yep even the DT Swiss hub has slipped already in eco mode. I’m hoping it is only a once off. A wheel builder advised the only hub that would handle my motor is the Chris King hub. I just didn‘t want the sound of a swarm of angry bees they make when free wheeling.
3x3 IGH... Once you go sans derailleur, and perfectly straight chainline.. you'll never look back!
Those are the small details that they never seem to mention. Then the "why not upgrade to our latest model" every forced visit to the LBS
3x3 IGH... Once you go sans derailleur, and straight chainline.. you'll never go back!
IGH is only 250nm rated. DT Swiss hybrid 350 is 400nm and Chris King 1000nm. IGH is probably fine for road. You need more for racing single track when you launch and land under power.
I just asked AI:
Side-by-Side Comparison for High-Torque Mid-Drives
Chris King Boost 6-Bolt 12x148 Rear Hub
$522.00
5.0 ★ (14)
Onyx Classic Rear Hub
$550.00
White Industries CLD Rear Hub
$467.00
Torque Capacity
1,000 Nm (RingDrive) / 540 Nm (hub)
Torque Capacity
Rated up to 1.5 kW mid-motors
Torque Capacity
Not e-bike rated; 3-pawl design
Engagement
72 points (5°), simultaneous teeth
Engagement
Instantaneous (0°), dual sprag clutch
Engagement
24 or 48 points (15° or 7.5°)
Freehub Sound
Loud, iconic "angry bee" buzz
Freehub Sound
Completely silent
Freehub Sound
Classic, moderate mechanical click
Freehub Material
Stainless steel or anodized alloy
Freehub Material
Alloy with steel anti-notch inserts
Freehub Material
6Al-4V Titanium (resists gouging)
Maintenance
Periodic preload & RingDrive lube
Maintenance
Low maintenance; sealed sprag clutch
Maintenance
Very easy; standard Enduro bearings
Why Each Fits (or Doesn't) a Powerful Mid-Drive
Chris King (Best Overall Durability)
$522.00
Chris King Precision Components& more
5.0 ★ (26)
According to NOBL Wheels, Chris King's helical RingDrive system is tested to 1,000 Nm of torque, easily handling high-output motors like the Bosch Performance CX or Avinox M2s. Because all 72 teeth engage simultaneously, the load is distributed evenly rather than concentrated on a few small pawls.
Onyx Classic (Best for Silent, Smooth Power Delivery)
$245.00
LoamLabs
Mid-drive motors often cause harsh drivetrain "clunk" when engagement slack is taken up under power. The Classic model (skip the lighter Vesper) uses two full-width sprag clutches rated for mid-drives up to 1.5 kW, eliminating engagement lag and freehub noise. [1, 2]
White Industries (Best Freehub Material, Lower Torque Overhead)
$342.64$403
Lenny's Bike Shop& more
While White Industries uses a titanium freehub body and 4130 steel axle that prevent cassette splines from gouging under heavy torque, it relies on a traditional 3-pawl system. Reviewers at Blister Review note that high-torque riders should stick to the 24-tooth drive ring rather than the 48-tooth version to maximize pawl strength. [1, 2, 3]
