American Customary (a.k.a Freedom) Units vs Imperial vs Metric
As a pro architect and hobby woodworker, I prefer imperial units. Aside from just being used to them, base 12 divides in half, thirds and quarters evenly, which are extremely common operations in design at both building and furniture scales. Base 10 divides in half and fifths and thats it. Most materials I deal with are imperial in the US, with some exceptions (like baltic birch plywood is generally metric thickness so what is sold as 1/2" is actually 12mm so a bit thinner).
Aside from that, eh. I'm reasonably good at mentally converting most common units. I model stuff in cad for 3d printing pretty regularly and most 3d printing software is metric so I either have to design in metric or scale it when I go to print. My shop has a full set of wrenches/allen keys in both imperial and metric and I run into both. Most bike hardware is metric. Shop tools are a mix (modern imported tools tend to use metric fasteners, older tools are more commonly imperial, but you find both everywhere).
I just remember that 1in is 25.4mm, 100km is 62 miles, 1kg is 2.2lb and I can mostly work backwards to convert things in my head and be reasonably close when I need to.
On last Saturday, my mate Krzysiek was to replace the inner tube in his vintage bike. I wanted to help him with any tools I had with me. No chance! He needed a 15 mm wrench (and it got stuck inside his frame storage). He didn't use Presta valves but Schrader. He had to be self-sufficient!
Way back when I used to commute on a fixie, the cheap bolt on hubs my older bike had used 15mm nuts. Super common on bolt on track hubs in the US and Japan. I kept a shorty 15mm wrench from Sears in my saddlebag as a solution. Eventually put Phil Wood hubs on that bike which used an allen instead (still metric, but a size that most bike multi tools had).
@jabberwocky: Before the hard times of nowadays, I bought Mirrycle mirrors for several times. As long as the product came from Amazon, all sockets were hex 3 mm despite Mirrycle is an American product. Once, I bought a Mirrycle from a strange seller in Germany. That crook sent me a mirror with imperial sockets! Yes, there was an appropriate hex key in the package. Once that little key was lost... (My brother keeps the mirror, he has got all tools).
Bike hardware is almost entirely metric, even in the US. I assume its just because bikes historically were made in Europe so European sizing mostly drove the bus for standards. But there are weird exceptions. Pedal wrenches are generally 9/16". Bike chains are 1/2" pitch. Handlebar clamps are measured in metric but convert to standard imperial (standard 25.4mm is 1in, oversized 31.8mm is 1.25", etc). MTB tires are generally described using imperial (i.e. 2.4" wide) while road/gravel uses metric for widths. I think being a bike mechanic is probably a good way to develop mental flexibility when it comes to units. :)
Two normal steps are about a meter, depending on the length of your legs. Unless you are very tall and have very long legs a meter is an uncomfortably long step.
In the US military, a step has been 30" for generations, I believe. A meter is just about 40", so a step is 3/4 meter. Often, a pace is 2 steps, or 5 feet by military specs. The military quicktime cadence 120 steps per minute, or 100 yards a minute, or 6000 yards an hour. 18,000 feet/5280 is 3.4 mph, or 5.48 km/h.
A Roman mile was 1,000 paces. It translates to 4860 modern feet, so their paces were abut 58".
A typical metric car wrench set. The 15 mm bicycle wrench is not here. I also think I needed M18 for the nuts for the hub-drive motor.
I don't think Torx has any relation to Metric or American sizes.
Hmmm... the set skips both 15 and 16mm. They're 12-point rings, so a 16 might have worked on an M15 nut.
It's nice that Torx isn't Metric or American. That way you don't need 2 sets!
Within the last year, that happened to me on a new handlebar device. I think it was something where the screw was harder to reach than on a mirror. I think Torx was a worthwhile invention. Fewer sizes, and a fit loose enough to make it easy to connect.
I don't think so :)
Regarding different sizes of bicycle parts, many are certainly inherited from English ones. Nobody, however, makes the fuss with, say, 27.2 or 31.8 mm. What is great are the standard hex sizes in cycling! For instance,
Yes (we use 15 mm for that) but good pedals can be loosened/tightened with a hex 8 mm key.
My late Dad would have certainly agreed with Jabber regarding the sizes of the U.S. construction material. I could've already mentioned that but he had to add an extra floor to the house of his old acquaintance in America and was charmed how easy everything was!
A question to you. We the Polish have funny names for these adjustable wrenches:
French (Left)
English or Swedish (right)
What are the proper English names for those?
Ya, we Poles have many funny names if you think of it... Allspice is "English Herb" :) But I digress.
The single reason we havent fully accepted metric is because the French invented it.
Wong. I worked as a transmission mechanic during the changeover, 90's. GM metric threads were totally different than Chrysler threads, which were totally different than Mercedes threads, which were totally different than japanese metric threads. Ford stayed SAE for the time of my employment. So instead of a shop having bins of standard SAE threads, usually coarse, a lost nut had to be ordered from the dealer. A lot of times the ship time was 4 days from Atlanta or NJ. The shop I worked for stopped supplying bolts & nuts entirely. I had a warranty return because I lost a suspension nut into a hole in the A-arm or frame, I used a nut I found, and it fell off under the stress of road impact. I believe the intent of metricfication by the big 3 was to kill independent repair shops. As they have done now, with copywrited software in every gadget protected by 99 year rights, just like Mickey Mouse.
Imperial & SAE threads were totally different in the sixties. Bicycles followed UK practice in the sixties, followed by Chinese metric. There are still 3/8" x 26 tpi axles on rear on some bicycles, which was totally weird. Standard 3/8" thread under SAE was 3/8"x18 or 24 TPI.
Joe, @Chargeride was joking :)
Metric sizes in Europe and elsewhere in the world are standardized and practical, just saying. It might be hard to get it by an American but it is the fact. Besides, I wonder how Chargeride describes his body height. I'm 173 cm, or 1.73 m.
The best metric standardization ever is the ETRTO, the European Tyre and Rim Technical Organization. As anyone can understand, the rim and tyre sizes are a mess. ETRTO makes all crystal clear. Your tyre is 42 mm wide and the inner rim diameter is 622 mm. It is 42-622 not 700x42c nor 28x1.65" Next, to resolve even more confusion, it is not 700x60c nor 29x2.35", it is 60-622.
I don't think so :)
French (Left)
Richard Clyburn and Edwin Beard Budding (inventor of the lawn mower) invented the English mechanism on the right. BAHCO, a Swedish company, improved it in 1891. In Shop class in 1959, we were told it was a Crescent wrench. On his 1927 flight across the Ocean of America, :rolleyes: Charles Lindbergh said his two tools were pliers and a Crescent wrench.
Not related to the units of measure at all!
I've watched a vid of an American who analysed and liked the contemporary Polish military ration. He also mentioned: "Did you know the Poles did a two-finger salute?"
The man didn't know we actually saluted the White Eagle. Therefore, there is no salute to the "bare head". You must wear a hat or a helmet with the Eagle to do the salute. No hat? Make a head nod instead. I know. I made a Sergeant Cadet during my military service :)
Not sure how British soldiers do the salute?
Whoever's interested, let me tell you the best military adventure of my life!
It was 1987. Our Cadet School was transferred from Cracow to the wilderness of Mazuria, a huge military range...
A cabaret. I weighed only 57 kg or 125 lbs at that time... :D
I started my 24-hour service as a duty NCO on some day. Our Lieutenant approached me to take my report:
-- Sir, I report iż nothing important happened during my service!
-- Cadet, it's "that"...
-- Sir, I report iż...
-- It's "that"...
The word "iż" is an alternate word for "że" = "that" if you want to keep your speech sophisticated :) I couldn't avoid saying "iż" and eventually the Lieutenant could not help himself laughing even if he tried to keep straight face! :D
Then, everything went bad. The skies opened, and it was pouring all the time! I only had a chance for a 1-hour nap during the night, and I slept soaked!
The next morning, it was still raining. I finished my service, totally soaked! My field uniform was black with water! It was the time for the morning parade. I was intentionally put in the front corner of the marching formation, so the command could see me. Trust me, the field dryer tent was organized immediately! :)
Several months later as a Junior Sergeant Cadet in Warsaw. The handgun is PW 33 (Tokarev model 33). I wear a "service uniform". We had three types: formal, service, and a field one. The pistol shooting stance per the regulation.
There was a delicious story from my Warsaw service. All my men could watch an American movie about a black helicopter.
-- Sir, we stand no chance against the American chopper? -- one of the privates asked
-- I guess we could try the squad firing with our AKMS-47s? -- I tried to keep the morale high :)
-- Sir, I'm not gonna lie. We'd rather run away :D
The year later the system had collapsed :)
Isn't that a photo of Michael Caine, the Korean War veteran? ☺️
We had a two-finger salute in the Cub Scouts. In the war, I used a one-finger salute.
Mine was the first battalion in history to be flown overseas directly into combat. It took 37 hours, and for some reason my plane wasn't pressurized. That was lucky because it didn't have a toilet, and deprivation of oxygen works like suspended animation. We arrived as fresh as vacuum-packed coffee.
I think I was the first one to make contact. My platoon had stopped in a grove. It was around 6 PM and too overcast to see if the sun had set. I was eating out of a little can when my hair seemed to stand on end, and I knew somebody was aiming a rifle at me. I looked across the rice to a spot in the tree line 300 meters away, but the tree line was too dark to see anyone. I wondered if he had a scope to see me. As a former Cub Scout, I felt that I should alert my den, but they would say I was just having a bad hair day.
I decided to walk toward the sniper until he felt he had to shoot. Then everybody would know he was there. I decided not to point my rifle at him because that would be rude and he might feel justified in his own rudeness. I held my rifle down by my hip. I extended my other hand with the palm up and a finger raised in the international sign language for "please shoot!" I didn't know how I could dodge a bullet that arrived before the sound, but I could figure that out when the time came.
By the time I was 50 meters out, I was getting scared. If the rifleman were truly ruthless, he'd make a fool of me by not shooting. I'd never live it down, strolling out in the paddy for no good reason. Just then I heard the faint pop of a 60mm mortar. The enemy had come through for me! My reputation was saved! I was so relieved I turned a somersauit. I came up feeling foolish. Unlike an M-1, my M-14 had a magazine box sticking out, and I could have hurt myself. I reminded myself that loaded assault rifles aren't toys.
I had plenty of time to dodge the round, but I stayed where I was to see if it was true that a mortarman's first found would probably miss. It hit 30m away. When I heard the pop of the second round, I knew I had at least 10 seconds to relocate, but I remained to find out if it was true that a second round would be much closer. It, too, was 30m away, but in a different direction. He fired 4 more rounds, each landing about 30m from me. Perhaps he'd never before encountered a foe chivalrous enough to approach with an international salute. How could he hold his mortar tube steady if he was shaking with laughter?
As soon as the sixth round exploded, a machine gun began firing just over my head. The tracers were so close that instead of tipping my head back to see, I rolled my eyes. Vindication! They were coming from the same place I'd been pointing as I walked, sighting along my arm as if my vertical finger were a rifle sight. The gunner was not shaking with laughter; I would have been killed if he hadn't kept the stream perfectly steady, inches above my head. After 5 seconds, I grew concerned. As a good sport, I wanted to run over there long enough to tell him to let off the trigger before he overheated his barrel. It kept on and on. After 15 seconds, the tracers started to spread. I was in danger of being killed accidentally because the barrel would no longer keep the bullets flying exactly where aimed.
That machine gun could have cut me in half. It looked as my new friends had avoided harming me while destroying 50 pounds of mortar shells, 50 pounds of machine-gun ammo, and a machine-gun barrel. The one-finger salute is the key to international diplomacy!
Hey, Spoke, show us some pics of your models!
Here's my only model. I keep a ruler in front of it to avoid confusing it with the original, in case I forget that I traded it in, in 1972. The original had a Bates bicycle seat (a rusty steel pan) bolted to the frame in front of the fender. Sitting with my butt pressed against my heels was uncomfortable, but handling was lightning fast.
In 1971 I rode it on a 16,000 mile trip. One June morning as I headed northwest across Saskatchewan, I learned why aviation mechanics don't reuse cotter pins. I pulled the clutch lever and nothing happened. A cotter pin had broken, allowing a hinge pin on the back of the transmission to come out. That pin had hinged one end of a 5" alloy lever. On the other end, the clutch cable had passed between two fingers, curved to hold the barrel fitting on the end of the cable. Near the hinge end, the lever pushed a rod that ran through a transmission shaft to disengage the automotive clutch.
At some point since my last shift, that lever had fallen off. The towns I'd passed were on the other side of the tracks, which meant it could have been hundreds of miles since my last shift. I slammed it into gear and headed back. Eventually I gave up. If it was on the pavement, I might eventually find it that way, but it could well be in the gravel. I resumed my northwest heading. On my right, the railroad was several feet higher than the road, so I didn't know what was beyond. As my next opportunity, I turned right, crossed the tracks, and entered the 19th Century.
The main street was wide with hitching posts. I saw no pavement or cars. I saw a cafe but no people. As in the 19th Century, the utility poles had dozens of phone lines. I followed an electric line down an alley to what looked like a blacksmith shop. The wide door was open. It had acetylene tanks instead of a wood fire. Unlike a blacksmith shop in a western, it had a drill press. It still looked like the 19th Century.
The proprietor looked at my bike and envisioned just what I needed. He seemed to spend hours with his drill press, red hot metal on an anvil, and other processes. Maybe it wasn't more than an hour, but to me it seemed longer because I didn't know how I could pay for such skill. He installed his unique lever, a pin, a cotter pin, and a spring, and it was as good as the BMW factory. I asked what I owed him. He said nothing. He said in 1912, his Model T had bogged down. A farmer with a team and chain had come along and refused to help him because the farmer was a Russian immigrant and the motorist a Polish immigrant. From that day on, the proprietor had helped stranded travelers for free.
In 1912, few could afford a Model T. If this guy had one on the frontier, his blacksmith shop must have been well-established. He must have been over 30. When he helped me, he must have been nearing 100 years old, but he seemed as able and healthy as a man in his 40s.
If I'd known then what I know now, I would have rendered a two-finger salute. At least I had the good taste not to say goodbye with a one-finger salute!
