Entered My First Mountain Bike Race............with the Frey Beast
juggernaut
Australia
Following on from my recent first gravel bike race post, my same friend mentioned he was participating a mountain bike race for the second year in a row. This time on his Amflow Pro whereas previously he rode an analogue Specialized. Again the courses which varied in distance - 100km, 70km, 40km and 20km. For some reason e-bikes were restricted to only entering the 40km and 20km distances.
My friend and I entered in the 40km race (which was technically 42.7km) with 618 metres of elevation.
It was a last minute decision and so all I did was check my brake pads, clean my rotors and swapped my Schwalbe Albert Gravity Pro's (soft) back on. I left everything else as is.
I don't know how many competitors in total were there over all the races, but there were 297 in the 40km race with 27 in the e-bike category over this distance. The e-bike category was given a 5 minute start over the main 40km riders. The 100km and 70km started together and were the first to leave - we started after them. The 100 km and 70 km races had a Northern and Southern section. They did the Southern section first. The 40 km race used the vast majority of the 100km Northern section course. The courses comprised of a series of technical single track trails joined by fire trail gravel roads and our race had 4 timing sectors.
Given I have very limited single track trail riding experience, coupled with the fact I had never ridden the Beast on a mountain trail in anger before, I had serious my doubts about my capabilities. Sure enough I went over the bars once and laid the bike down on it's side through a fast corner after losing the front end! My competitive nature come the the fore and I jumped back on and continue the race after both mishaps. I also missed a turn marker from the fire trail gravel road into a technical trail and had to double back. I also had numerous pedal strikes and bent the shaft in one of the pedals which meant I was riding with an eccentric pedal for the remainder of the race. I also caught the tail end of the 20km riders so that also slowed down progress trying to overtake on a single track trail.
All in all it was another great personal challenge. Very different from my previous gravel race which required battery and body management. The gravel race was very physically harder on my body from a fitness point of view whereas the mountain bike race required your utmost skill, focus and attention, especially at speed.......as I discovered during the race.
My only goals for this race was to not come off and finish, only achieving the latter.
The results..........I finished 14th outright out of the 297 competitors, and 10th in the e-bike category!!
Looking at the sector times I was outright 10th (10th in e-bikes) after the 1st sector, outright 8th (8th in e-bikes) after the second sector, outright 24th (15th in e-bikes) after the third and outright 14th (10th in e-bikes) after the fourth sector. Pace was 20.5 km/h over the entire course.
Amazingly, I was also 15 minutes behind the fastest competitor.
My friend with his Amflow finished just over 5 minutes behind me.
Pic for attention.
A 100km pedaled race, good god.
Amazing result, the Frey has the power, not nimble though.
I presume you beast moded it.
State and National riders ride the 100km race as it is a sanctioned event.
Frey’s biggest advantage is its battery capacity so I was able to generally run level 3 in Eco mode for most of the race (but used between 1 and 5). Shear power can’t be exploited on technical trails so I still had over 40% battery left. That said, my Garmin showed I hit a max speed of 47.7km. My friend with his Amflow ran out of battery towards the end of the race so couldn’t keep up.
The bloke parked next to me has done the 100km race but was doing the 70km this year. He also did the 125km gravel race back in May. I asked him which was tougher. He said whilst the 125km gravel race is tough because of the elevation, the 100km mountain bike race is brutal as you are using your upper body and on your feet a lot.
As per most events, there’s no podium for the e-bike category.
Same in Poland on e-gravel "rallys" now. I have got several gold and silver in the past. I'm losing now to young people riding low-power lightweight gravel e-bikes. These guys ride unassisted at the high speed on the flat and descents and only use the assist on the climbs.
I got a SUB 5 (hours) on a 100+ km ride with some 1,400 m elevation gain, I think the 5th place out of 10 in 2026. Not racing anymore! Just enjoying my rides!
My first gold ever :) Usually: a. Either a competitor had a bad luck or. b. The competitor could not stand the harsh conditions of the ride.
Since 2026, there's no podium and no "race" but "a rally".
They don't need to. They keep it in low assist mode and use the boost button when they need to. It's very efficient. At least that's what's happening out here. The guys on Levos and Orbeas are getting smoked.
I couldn't say what assist mode my friend uses. From my observation there not popular e-bikes for comps over any sort of distance.
1470 Wh is an obscenely high battery capacity. Have just run some stats of mine:
  • 118 km / 1,400 m elevation: 924 Wh (measured)
  • 125 km / 1,700 m elevation: 981 Wh (measured)
  • 68 km / 900 m: 608 Wh (as above)
The main difference being: my rides above were all on road. Those were closed loops so half of the ride were ascents and the other half were downhill, globally.
Was your race all uphill? Did you use any assistance on steep descents?
The unanswered question: What e-bikes took the three first places?
Congratulations. What was the race?
No idea what e-bikes took out the first three places. No way to find out either.
Yes, I would have used assistance on steep descents if the track allowed for the speed. I would have used whatever level of assistance in Eco mode provided the greatest speed wherever I could. My max speed was just shy of 48 km/hr and was hitting close to that on numerous occasions, and min speed was probably down to walking speed on the steepest and tightest of climbs. The course is virtually all pea gravel, which is not exactly conducive to traction. So I was a little gun shy of unleashing the full 1800 watts in Sport mode with my rookie experience. As it was I was pushing it and stacked it a couple of times.
Race was uphill and down hill - see below details and elevation profile from the website.
40km Wallaby
Actual Distance = 42.7km Total elevation gain = 618m
A big day out without the commitment. The most popular distance on the card. E-bikes welcome.
Elevation profile - North
I'm wondering if the disparity in range is because the Amflows in your races are locked at 25 km/hr. My friends Amflow is unlocked.
They are not. All of them have been VPN configured. However, they are racing XC, not gravel, and the riders are skilled at power management. I don't know if your race was 100km or 100 miles, but either way, it would take a lot of battery management for a Gen1 AMFLOW bike to make that distance. However, the Gen2 bikes, minus the PL, are all dual battery capable now.
The 100km course is classified as XCM race. We rode 42.7km of that course, so I guess that makes it an XC race.
Yep the Amflow guys over your neck of the woods have to manage their batteries. Other e-bikes with larger capacities and extenders don’t have to, or not as much over here. Some racing rules only allow the original battery, so extenders might not be able to be used in some races.
I’ve seen pics of the dual battery Amflows which looks like a home build IMHO with the overall integration and Velcro strap. Also only fits the XL and XXL size frames I believe.
