New type Ebike lock...
Wetstuff
I have been fiddling around with those thin 'cable locks... sometimes adding one on either side of my trike's rear basket so it might confuse someone cutting the first one only not being able to get away fast. (I also suspect Trikes are not prime targets...).
But, I found one I really like: a disk brake lock on Amazon. This one is quite simple, durable and may be a small target for a grinder. It comes with an internal screaming alarm, but I dismantled it by removing the batteries as I am really not fond of gratuitous noises... Visibility and bulk may be sufficient. As I do not leave this unattended for any long periods, I suspect (X my fingers) I will be in possession of this trike for a long while. Jim/Maryland
Buy a cable reminder. If you have a Cycle Gear near you they sell them. It's a bright orange, wound little cable. Put one end around the lock and the other over your grip. I use one religiously for my motorcycle lock, as I lock it thru my front wheel. I don't wanna drop my baby on the ground by forgetting to remove the lock first!
Those disc locks work good enough. They can be a pain to angle grind (don't ask how I know) and me, I would have left the alarm operational. Pad locks work as well and are harder to angle grind because they wiggle around, unlike the rigid mounted disc lock. Stupid side thing I do with old locks:
Even have a old U-lock that's on its last leg? Or a pad lock that no longer works well? I save them and toss them in the trunk of my car. They can be fun to lock down something in the wild for whatever reason. A motorcycle that made you mad, a bicycle that pulled out in front of you, a gate that should be locked, doors to a business with the loop handles that needs to be closed for awhile. Around someones neck like a necklace? Use your imagination. These are older U-locks that can be removed without much fuss, but can still cause a huge headache for someone. I have 2 ratty Onguard U-locks and 1 heavy duty but crunchy pad lock in the trunk right now, waiting for new homes. All of them have one key in them, in the unlocked position, and are probably only good for one more lock down. Toss the key on the roof of the building or down the sewer afterwards, then park away from the lock down scene and pull out those binoculars you have in your cars door pocket and watch the chaos ensue.
Interesting. Thinking cable locks, even multiples, would present little resistance to a bolt cutter ....I needed to upgrade to deter the guy with a grinder. The large metal 'folding ruler' style Lectric provides is cumbersome, heavy and often difficult to find a place to attach other than the trike itself but, I have used it in places where my little cables did not seem to be enough; places with low visibility/exposure. But, I am lazy... I just want to do this quickly. Since it only takes a second, I will still use it in places where the exposure is low risk.
I think the biggest problem with a padlock is the guy with the grinder will be slowed somewhat by the high heat and noise generated, but the depth of the cut is still pretty small. Scooter mentioned a 'reminder cable; this does come with a brite cable to hang on your handlebars, but I figure.. 'if I can't see this' then I better consider Uber instead of the trike for transportation. Cheers.
Jim
@Wetstuff, the REMINDER that the rotor lock is intalled/present on your trike is built-in...the lock's alarm which you deactivated (by removing batteries). I used a rotor lock on my motorcycle, and I used the reminder cable, attached next to the engine Starter/Kill Switch, so it was difficult to ignore. on a bike you don't have that initial step.
I still use that same disc lock, as a secondary lock, along with my Hiplok U-lock on my eBike.
You can add a bigger, bright "flag" to the end of the reminder strap that you attach to your handlebar. This is a neoprene keychain strap from AMZN:
Even have a old U-lock that's on its last leg? Or a pad lock that no longer works well? I save them and toss them in the trunk of my car. They can be fun to lock down something in the wild for whatever reason. A motorcycle that made you mad, a bicycle that pulled out in front of you, a gate that should be locked, doors to a business with the loop handles that needs to be closed for awhile. Around someones neck like a necklace? Use your imagination. These are older U-locks that can be removed without much fuss, but can still cause a huge headache for someone. I have 2 ratty Onguard U-locks and 1 heavy duty but crunchy pad lock in the trunk right now, waiting for new homes. All of them have one key in them, in the unlocked position, and are probably only good for one more lock down. Toss the key on the roof of the building or down the sewer afterwards, then park away from the lock down scene and pull out those binoculars you have in your car's door pocket. You could even use a color wheel to pick the best spot to park and watch the chaos ensue.
That disk brake lock seems like a good option for a trike, especially if you’re mostly trying to deter opportunistic theft rather than protect it while it’s unattended for hours. I agree that visibility and the inconvenience of dealing with the lock can be enough to make someone move on to an easier target. Removing the alarm also makes sense if you don’t want the noise. I’d still use a second lock to secure the frame to something solid whenever you’re leaving it unattended.
Fexi... Ya, I use it at the food store, Doctor's offices. Typically places I go are quite exposed/populated. Plus, what 18yr old hustler wants a fricking Trike anyway? I had previously used those small chains with a key lock, but no longer..even in the most visible areas. Strangers walking by don't know that 'you' own the bike; the hustler may simply be having problems with 'his' eBike?! If I have a prolonged stay for some reason: Uber ...you don't want to leave bait out too long! Cheers.
Jim
I just realized, I have the disc locks little brother, the Cafe Lock. I have a cafe lock on my RadRunner with the chain extension. I use it when I run to the grocery store. I kinda look at it this way. If someone goes thru the trouble to cut my cafe lock while I'm grabbing stuff to make tacos, turn the battery back on and figure out how to get it moving when the mystery code flashes on the screen (It has a random, annoying gremlin.) then good for them. I use the cafe lock to slow down the Grab and Run clowns just like Wetstuff does. When my ebikes are in the garage the real heavy duty lock comes out. Thieves LOVE enclosed garages and sheds as they provide privacy and sometimes tools when stealing.
What kind of trike you ride Wetstuff? My wife has owned a few motorcycle trikes and 2 bicycle trikes. She has balance issues. She now just rides on the back of our Lectric Xpedition.
OO'ter... I'm kinda lucky, the trike lives in the apartment with me. Your wife won't have a lick of difficulty with her experience. I have been a 2-wheeler, powered/unpowered since I was maybe 12 ...~70yrs ago. I had to accept slowing down in other areas, so this fits right in.
My trike is the Lectric 750. I am now >600mi with basically no few-to-no issues.. I have not needed Lectric help with the exception of a RR wheel that wobbled noticeably. They were kind enough to replace it. I ordered a truing jig to see if I can straighten the original. A Youtuber 'You Can Do This' has a nice tutorial on how to adjust the spokes to improve the rim alignment. ...ya, she's not going to have a problem. Cheers.
Jim
Wetstuff, my wife pretty much quit riding, though she's thinking of a Can-Am Ryker as a possible next ride. But it lacks power steering and she doesn't think she can manhandle it at low speeds. She's now in her lower 70's. I bought her a "surprise" etrike, a BUZZ mid-drive, but the surprise landed on me when she said it was too fast. It did haul butt off the line when in the upper assist level. I ended up trading it at a loss so that lesson was learned.
One vehicle she had. I found a nice Honda Silverwing scooter. We ended up purchasing it and I was riding it while waiting for the Motor Trike kit to arrive. That Silverwing was fun while on two wheels! Then the trike kit arrived. She rode it for about a year and lost interest. I had zero interest in it because of the trike kit. She says "Just remove the trike end and put it back to stock." like the $5000 installation fee was a simple bolt on. It stayed a trike when finally being sold. I have a Honda PCX as my daily, basically a baby Silverwing. I have a weird relationship with scooters. I LOVE them but once a brand gives me grief they're off my purchase list for life. I also need local support that I can trust.
Whooooo'wee... I looked at that Can-Am! That's a rocket ship in disguise. I see a lady in leathers with silver hair streaming out back. I doubt steering would have been an issue, a throttle limiter would probably be appropriate. Good for her. Jim
