Revamping a bike trailer?
Nvreloader
Western Nevada
Hey Guys
Since, I can't find what I want in the single wheel form of bike trailers, I am left with this option....
This is what I want to do,
Add a second wheel to this single wheel type of bike trailer, to better increase it's handling when using on single track trails, hauling stuff in and out.
This type of single track off road bike trailer, generally ONLY comes with a single rear wheel,
see info here, of these types of bike trailers.
I'll have a second wheel (copy of the OEM wheel), and I'll have to remove the OEM wheel frame, all parts from the trailer body, then figure out the needed spacing between these 2 wheel cages, then reweld both to the proper spots, and both rear wheels will have coil suspension.
And I think I should have a rear brakes, on the rear trailer wheel, and need to figure out how to do that on one or both of the trailer wheels. I am getting too old, to be packing out game quarters on my back, anymore.
I will be using my Miller 211 wire feed welder, using flux core .030 welding wire.
It's been a while, since I have welded anything with this .062>.080" thickness tubing, and I'll need to brush up on welding this type of tubing, I know.
If you are a welder and have welded this type of thin walled tubing,
any thoughts or suggestions would be greatly appreciated.
yrmv
MIG welding thinwall tubing can be done, but it's tricky. There's a fine line between adequate penetration and burning through, which is why TIG or gas welding is preferred. With MIG or TIG, you will need to stress relieve it with a torch afterward or you'll be asking for cracks.
In the aircraft world where thinwall chromoly structures are common, gas welding is still the standard. I believe one manufacturer uses MIG, but they had a huge learning curve and a lot of problems until they got it dialed in.
Thanks Guys,
My thoughts about the Hydro brakes was to use a set up for the trailer, then have a quick release for the brake handle (think short handle bar stub, on the Hbar), when the rear brake was NOT needed or used, I would remove the complete system from the bike Handle bar, back to the trailer, store in a HD pouch, in the trailer.
Then when needed, restring the brake hand/line to the front bar and clamp down for use, that way I would not need to bleed/mess with the line etc, just use some zip tie's to secure the line as need to set up everything for use..
Would a properly tuned Hydro brake system work for that distance?
Overall bike length of 80" and the trailer length is 80" =13'.6".........
Front wheels with the brake disc are readily available, and I could weld a brake base to the rear tire frame, as needed for the brakes.
Where I got the photo from was from another hunter on the East coast, he had a single wheel bike trailer, and stated it was squirrelly when loaded and want to tip sideways all the time, regardless how the trailer was loaded..
When he altered his trailer, (added a second wheel), he said the performance improve 100% and he could haul better (heavier) loads with no problems, when using single trails. He is using this single wheel trailer, same one as the photo.
All-Terrain Cargo Trailer
Enhance your outdoor escapades with QuietKat's rugged Cargo Trailer. Boasting a robust aluminum frame, 20" wheel, and top-notch suspension, this trailer supports up to 100lbs of cargo. It's your ideal companion for camping, hunting, and fishing - Order now to pair with a QuietKat eBike.
I have 3 different friends and they all have single wheel trailers and they all say that their trailers have the same results, all are different brand names, but with smaller diameter wheels.
Your thoughts and suggestions......
Tia
If you don't need the power of a hydraulic brake, and instead use a hybrid cable actuated hydraulic brake, you can use a Ritchey brake cable coupler to easily disconnect the brake cable from the trailer.
Stomp
This will be used for hauling heavy loads of game/gear off the Mtn, with steep grades coming down hill, loads can be around 200# + the bikes/my weight = 300#'s =, so I believe that I should have/need good HD rear trailer brakes, to help the Wart Hogs brakes, in controlling these descents, lots of rocks/brush that would be hard on this Old bod.....lol
I don't known of any other types of brake systems that should work.
I have a cable system rim brakes, on my other bike, and I know that they won't be the best to use..
I'll change the rear tires to 24">26" size, from the IEM 20" size, as to match the bikes tire size......IMHO.
Your thoughts or suggestions..........
Tia
That's a lot of weight. I was thinking of a cable actuated hydraulic disc brake, like the Tektro HY/RD, but that may be too small, and you didn't say if your bike uses brake cutouts. The HY/RD won't have them. I think that you're better off looking at Magura full hydraulic.
Stomp
Thanks,
Here is my bike, with it at a local fishing hole, and the better half in her kayak fishing.
The trailer will be used mainly for this bike, but can also be used on my Juggs 4 bike.
Tia
Stomp
Sorry, I was speed reading your reply, and missed your question.
Yes, both of my bike use brake cutoff's.
My plan? was to add another brake to handle just the trailer,
completely separate from the bikes brakes.
Which I don't know if that will work? and if I should have brakes on both rear wheels?
I am running 203mm brakes on the main hunting bike (Wart Hog),
and I know they work as they should, as I have found out during a couple panic braking situations (Dam cars).
Tia,
And to add some more info,
after looking at the 3 other brands of single wheel trailers, I have access too,
I think I can mount the extra wheels, without any welding, just by using
4 -1/4- "U" bolts per suspension plate.
I just have to find the correct size on the mounting inside width of the plate that contains the suspension parts, and do some careful measuring.
I'll know more when my trailers get here, as I have a couple in route, somewhere
per ups.
Tia
I took a look at your trailer setup, and I think I understand what you are trying to do. I would ask your friends about the brakes they used when they converted to two wheels. I would only use one rear brake for two wheels if the trailer had a spinning axle that connected both wheels. If the wheels spin independently, a brake on one side and not the other is not going to do well.
Take a look at this site. They are focused on recumbent trikes, the reverse of what you are focused on. You might be able to use one or two of those friction brake levers next to your cutout levers for the trailers. I would also look at the Ritchey brake cable disconnects so that you don't have to unbolt the brake levers to remove the trailer, and strap down the cables to the frame when you attach it. The levers and cables would stay in place after disconnecting the adapter. What brake calipers and rotors you use totally depends on your trailer and wheel setup. If you can, use a cable actuated hydraulic brake like this one, you may get more braking power.
Thanks Stomp
I am basically just adding a second separate Suspension wheel to the rear of the trailer, wheels to be mounted far enough apart, but staying inside the trailers frames width, to fit on single track trails.
And each wheel has it's own suspension/axle,, to better support the load capacity's and reduce the tilting when loaded etc.
The original builder/adapter didn't supply any information about having any brakes
on the rear wheels, that was my brain storm.....lol
Thanks for the info on the brakes, have to read more.....
Tia
Update,
Have a couple of trailer coming, it will be 10 days + to get here, from the East coast,
per shipping info. I have a way to add another rear wheel, without welding....and can change back to OEM configuration with no damage to the trailer frame.
Will update when the work starts...............
Well, I finally got another update, the trailers are in Reno NV as of 6:02am today,
100+ miles away, maybe tomorrow??
I got the trailers on Friday afternoon, working on the 2 conversion shock back plates,
I haven't decided on which way to go, waiting for the steel to get here.
More later,
Tia
As an update,
the steel got here, made a pattern to fit the trailer frame, attached it to the frame,
fits and works, attached the rear frame/wheels, looks good.
But, I was not satisficed, revamped the shock locking plates, for better strength
added several bolts for more security, looking better.
Need to attach the wheel frames to see how it looks and feels when sitting in it.
Then I'll do the tongue weight tests for 1 and 2 wheels, then do a couple of
road/trail tests, then do a final paint and hopefully get some photo's.
More later,
Thoughts and suggestions.......
Tia
If it's just a trailer there is no advantage to running those huge tires. Just go basic wheels, something small. Cheaper and more efficient and less likely to tip over
Land
Around here there is nothing but DG and sand, with abundance of rocks,
narrow tires are a death sentence when traveling around here.
Wide tires are necessary or you are pushing the bike to go anywhere.
Tia
Land
I am towing a trailer, but, if the trailer has small wheels, it just sinks into the sand/DG and you have a anchor you are pulling thru the sand. (Takes more effort to move.)
With wide tires, they float and ride on top of the sand/DG and it easier to pull the trailer thru. (Less effort to move).
Tia
Well Guys,
The trailer is done, finished making the rear wheel brackets, painted and attached them to the trailer frame, just waiting on the attachment bobbins to hook up to the bike.
Had to make a couple of special attachment brackets for the trailer attachment to the bike.
Then I can start testing the trailer out.
Yes, I have several photo's, in my phone camera,
I just have to figure out HOW to get the photo's here?
I think it looks kind 'a cool, myself, and "Sage" hopped in and gave me that look,
'Hey, Lets get this dog and pony show on the road"..........lol, he likes riding.......
I found out, that I can sit in the trailers basket and it won't tip over, with 200#'s in it,
the dual rear wheels makes a difference, compared to the single wheel option.
Thoughts and suggestions................
Tia
