Charge Smartphone vis display
Dima
In the end, all that’s left -emotions and feelings
Europe
Minsk
Did some one try to charge via cable like this ( i bought not original Micro A - micro B ) but not bosh original and it does not charge.
Are you sure that the dislay's USB port provides an adequate charging current? If not, no cable will help you.
Example: My commuter ebike's display and battery both have USB-A charging ports putting out 0.5A and 1.2A, respectively. The 1.2A port will charge my Samsung Note20 phone, albeit slowly. The 0.5A port won't charge the phone at all, but it does keep a 2,000 lumen headlight fully charged.
Sorry, can't understand the language. If he's saying that he can charge that particular phone with the display in question, then the right cable might be all you need. But do all phones have the same minimum charging current?
does not say anything ) about particular phones , he charges and that is it . Maybe i order this cable and let you know if it works !
The latest System 2 Nyon display does not allow for charging mobile phones, even slowly.
From memory, this has been discussed earlier on this forum.
Cheers
Latest system 2 ( do you mean Smart System or Gen 2 ) My engine has Gen 2
yes i remember that! but ! i thought that ORIGINAL BOSH cable may be appropriate ( anyway i emailed to the owner of the video ) for clarifications
That video is from 2020. If he mentions the Nyon in the video he is talking about the original Nyon which used the same mount and cables as the Intuvia that I see in the video. It supported charging.
Your Nyon is the my21 Nyon which does NOT support charging. Pretty sure that's all covered in the topics already linked.
