Specialized Turbo Levo speed remote switch not working
Homestead
United Kingdom
Hi all.
I have a 2021 Specialized Turbo Levo Hardtail and the remote handlebar switch does not work at all. I have swapped it out for a new one and still no joy, so I have rule out the switch and cable being the culprit. Any ideas what else it could be?
I'm not familiar with the Brose systems. Is the remote wired or wireless? If wired, does it connect to the system controller on the top tube? If so, does the button on the system controller change assist levels, just not the remote? If wireless, is the new remote paired to the system controller? Do you have an app that can verify connectivity between components?
Thanks for the reply. The remote is wired directly to the motor. The system controller (which is housed within the battery) still works but it is quite hard to change the settings using this whilst riding.
OK, that helps. So you ran the remote cable through the frame down to the motor connection panel. Are you 100% sure that you plugged it into the correct motor port? I was unable to find a connection panel description for that motor which has a remote port. The cable should be keyed so that it only fits in one port, but who knows. Two more questions, is this bike tuned/de-restricted with an aftermarket device? If not, have you performed a system reset on the system controller (TCU)?
Yes definitely in the correct port. 100%. No tuning or aftermarket device. I am not sure how to do a system reset on the TCU for my model......can't seem to find any info on it by googling.
@Homestead just take my advice. We, riders of Specialized e-bikes leave the work to Specialized professionals even well past the warranty period :)
Of course, you may ignore my advice.
Is your Levo equipped with a TCD-w or TCU? Are you aware the coin battery in these devices has to be occasionally replaced?
As a Vado SL 1 owner with little understanding of the bike's electrical side, I'd be heading straight for an authorized Specialized repair shop at this juncture.They've got the proprietary diagnostics and parts access.
Yes, easy for me to say with 2 authorized dealers nearby, but not taking any chances with my pride and joy.
@stompandgo: you even don't know what TCU is present on @Homestead's Levo Hardtail :) Certainly it is not the SL 1 TCU. It is absolutely not a Mastermind. It is the TCU for Specialized 1.2E (Brose), not for Specialized SL 1.1 or 1.2 (Mahle) unit. His TCU is from late 2010s.
That's why Jeremy and I say: visit a Specialized dealer. Every e-bike part is assigned to the WSBC serial number in the Specialized database.
Once, I needed to replace the display and the remote on my historically complicated Vado. The salesman was new to the dealership. He looked to the database, determined my Vado was a 2017 model and said "I'm sorry, we don't carry the BLOKS electronics anymore". I sighed and asked a competent person to come. Then I said to the experienced man: "You see, the electronics on my Vado was replaced on the warranty to the newer TCD-w(s) in 2020. I need the electronics of 2020 Vado 6.0". That man was not stupid. He searched the database and -- voila! -- found the assembly I needed. I still have it on my Vado.
Specialized is not simple. That's why we Specialized riders always seek a professional advice instead of misleading someone with misinformation :)
