Standing Up on ebike: safe?
The first ebike I tried was a cargo bike and the sales guy said "never stand up on an e-bike"- but I don't ride a cargo bike now. So just getting folks reactions.
I ride a cargo bike, often with cargo in the panniers, and I stand up if I am going to cross a bumpy stretch of pavement. Easier on the hips. No problem. I do have a throttle. The heavier the cargo in the panniers, the more stable it is. If I have an air conditioner, CRT television, or lawnmower on the rack at waist level, I do not stand up.
I have a mid-drive, I stand and pedal when tackling steep terrain on my ebike just like I did on my non ebike. I don't know what controls one would need to be changing while they are standing/pedaling?
A mid-drive loves a steady high cadence and equal torque at the crankarm. Pedalling out-of-saddle is not interpreted best by the mid-drive system.
Child's Play
I feel inspired now !!
I had that exact same bike, complete with the 🍌 seat and the sissy bar.
I see no reason why I can't install a 🍌 seat on my current ebike and hook the sissy bar up to my rear axle or swingarm?
I'd have to allow the seatpost attachment to pivot a bit, and I'd probably need to add suspension to the sissy bar, but I think it's doable !!???
I've already got the ape hanger handlebars and windshield from my other ebike that I can use.
Then I can learn to do wheelies !!!
They'd probably happen all the time, so I'd have to learn to Not do wheelies ??
I went for a ride today, stood on the pedals and waved my arms in the air.
Then I sat on my seat and waved my arms and legs in the air.
That was fun too but I was kinda slipping forward on my seat and it wasn't very comfortable. (I need to buy a unicycle seat for that trick.)
It was easy to navigate though, considering that the only touch point with my ebike was my ass. 😁
Whenever I coast, I stand on one leg, with the pedal at 6 o'clock. My butt remains on the saddle for stability, but my weight is on my leg, which nicely absorbs any bumps I might hit. If one leg tires, I can rotate the cranks 180 degrees and stand on the other leg.
That's what I do. 👍👍
I straighten my leg out and "lock" my knee to take some pressure off my ass, but my knee kept banging up against the suspension linkage.
So I put rubber bumpers on the linkage. 😁
I used ½ a neoprene footstrap cover with velcro from an old windsurfer.
It fit perfectly 👌
I don't lock my knee. They say it's inefficient if the saddle is so high that a leg straightens all the way while pedaling. Sitting, a locked knee wouldn't help absorb bumps.
In the style of old English utility/touring bikes, my saddle clamp is 36 cm aft my BB. Standing on one leg, I can lift my butt off the saddle by extending my ankle, so I know my weight is centered over the pedal. Having my center of mass so far forward of the saddle, I can sit on it without having much weight on it.
My leg doesn't straighten out while pedaling.
I have to push my heels towards the ground with toes up to lock my knees.
I have HUGE Pedal clearance on my full suspension ebike, so I can dangle my heels down a couple inches.
My ebike does all the shock absorbing for me.
I've got front air shocks with 160mm of travel, 4 point rear suspension, an NCX seatpost with a softer spring installed, and a gell seat cover on top.
I ride no-hands 95% of the time, and standing firmly on a pedal helps me to steer the bike.
I have to lean the ebike over into crosswinds while staying vertical in my seat, and a locked leg really helps me navigate.
It takes both hands for me to takes pictures while riding. 😁
