No, I would not significantly change any part of the original design of any bike. Major changes can cause problems.
Therefore, I was against the idea of changing the original design for
@bbrebis e-bike.
			Frames should not crack. Even extra special Specialized. I realize that some have cracked. It's a design issue.
It was 2017 when the modern commuter e-bike concept was in its beginnings. Yes, the original design issue was not to install the suspension fork on the Vado. After the redesign, Vado frames stopped cracking.
@bbrebis let me cover your points one by one.
			The e-bike I have now (Giant Explore E+ with 800Wh) is great ... but... slightly too heavy.
Any full power, big battery, mid-drive e-bike will be heavy. There is no way to change it given the current technology state. Not only is the big battery heavy but also the frame has to be thick to ensure the structural strength.
			but too big for me (29-inch wheels)
The wheel size does not actually determine the e-bike height. It is because 29" wheel bikes are usually equipped with narrower tyres than the 27.5" ones. If you look at two bikes, one with 700x47mm tyres and another with 27.5x2.6" tyres then you will find the outer diameter of both wheels will be about the same! Yes, your Explore E+ has 29x2.25" quite big wheels but that's not the reason the e-bike feels too big for you. Either, it is the wrong frame size for your own body or you need an e-bike with a Step-Through frame (the top frame tube lowered).
			Yamaha motor (I tried Bosch 2 years ago but found it too noisy)
I owned a Yamaha motor Giant e-bike and the motor was noisy, with a low grunt. It was especially heard in the forest.
			- Not a chain but a belt drive
Adding 2 kg to the e-bike weight (belt and IGH). Are you prepared to remove the rear wheel in case of a tyre flat?
Discussed above.
Well, what if I told you that you could travel light on 520 Wh one day but could use 680 or 880 Wh on a long trip?
20.5 kg is OK?
				Nothing delivers more power, speed, and range at such lightweight than Turbo Vado SL 2. It’s a high-performance machine carefully engineered to make fit...
					www.specialized.com
Easy to mount, lightweight, front suspension (Future Shock). 520 Wh battery in the frame, available 160 Wh Range Extenders in the form of a water bottle.
