Used Chopsticks, What Do You Do? Most Whimsical, Practical, or Creative Ideas.
Cleaning dog crap from your e-bike tire tread after you ride through a pile. 💩 🤬
Prize for the first good reason I've heard to actually carry a chop stick on my bike: Coyote crap's very distinctive stuff, and some trails around here are full of it — including certain sidewalks in my neighborhood's greenbelt.
Big howl-and-yip session on the canyon wall below our house just last night at 0200. Those guys really know how to party!
I used one yesterday to pack silicone grease into a shifter down the little hole where you feed a fresh shift cable. First I cooked the cable in hot bio-wax for a couple of hours. So it is slick as butter.
Yeah that'll be just great in a month or so when those cables get grit covered and cement themselves in place 🤣
I hate those cables. They're the reason I converted to hydraulic brakes and electronic shifting.
I've found that quality polished cables kept clean work reliably. I do give them (shifter) an alcohol wipe down at the first sign of an issue.
Brakes really never gave me a problem.
If your riding mostly in flat areas cable brakes work great. My first ebike had cable brakes and because I live in an area with a lot of uphill/downhill riding I didn't feel real secure with my stopping power going down a grade at 30mph :eek:. Once I switched my cable brakes over to full hydraulic everything was much better and my next bike came hydraulic.
Yes I find hydraulic better... but it all depends on use like you say. My now spare bike has cable driven hydraulic calipers and I never felt unsafe on the bike even at 30mph down hill. That bike is near half the weight of my current one.
I worked on a very high-end Ti bikepacking/adventure bike. It had super high-end mechanical brakes because you don't want to be way out in the wilderness and have a hydro issue. It was easy to dial the inner pad adjustment. I also have a gravel bike with GRX mechanically actuated hydraulic brakes.
When installing a quick link a chopstick can jam in the derailleur so it is not like fighting a bear trap.
Those that don't like mechanical road caliper brakes have never experienced good mechanical road caliper brakes.
They are also lighter weight. With less rotational mass. Really good stuff is really good. Bob White is a couple blocks away. I ride tuned calipers almost daily. Just tap once to shed rain before applying in those conditions. The fulcrum diameter is 622 not 160mm, so much more leverage pull; by almost 5 times. "Give me a lever long enough and a fulcrum on which to place it, and I shall move the world". I would rather a great chef make a simple dish than a mediocre one make a complex dish, every time, such as a very simple French pastry with one batter and five textures.
That's a little bit simplistic of an understanding. The amount of force applied by hydraulics is many fold. That's why heavy equipment such as earth movers all operate via hydraulics.
Ever use a hydraulic punch? I can punch a 4.5 inch hole in 1/8" steel with 11 tons of force using human input.
wasnt that way originally old earth movers were cable actuated.
Good point so let's start naming some things from the past that were mechanically operated verses hydraulic and or electrically.
BIKES. For the last several days I have been going analog and loving it. This tuned Giant Escape it thrilling and responsive and as fast as my Specialized Vado. But without any fillers, filters, or dilutions. It is like skinny dipping. Next it is getting Big Apples, 622-50's, so it will fly over broken pavement and cobbles and not get flats. I did use a chopstick when installing the bio-wax chain.
The better half uses a chop stick to lite the stove top burner,
and I can't figure out WHY that single burner won't lite.........
out of all of the 4 others..........that light every time.
