spokewrench
- USA
The motorcycle I bought in 1972 has threaded Schraders, as did the motorcycles I had before. I bought tubes with threaded Schraders for my first e-bike. When there's little or no pressure, the stem will stay put while I jam a chuck on. I'd leave the nut loose so that when I inflated, the stem would tip if the tube wasn't aligned with the hole, as you say.Yeah, threaded Schrader valves are nice. I've never actually had one on a tube before. (I think my dirt bike had them, but I'm not sure?)
I actually managed to thread a thin nut from a lamp shade or something onto my rubber Schrader valve once.
It was just the right diameter to bind on the rubber and thread itself down to the rim to hold the valve stem.
With decades of experience in pneumatic fittings, Schrader of New York City designed his valve for bicycles as soon as pneumatic tires became available in France.
The symbol of British values was the Raleigh Sport on which a 10-year-old girl in 1930 pedaled 100 miles over hilly terrain one day and 100 miles home the next, without hardship. Many Frenchmen, however, yearned to be the fastest in town. This led to high-pressure tires on narrow wood rims. Depending on the quality of the chuck and the skill of the cyclist, a Schrader can lose air as the chuck is put on and removed. That could be a big problem with a narrow, high-pressure tire.
The French revived an obscure valve patented by Etienne Sclaverand before there were pneumatic tires. It would stay closed unless there was more pressure outside than inside. The narrower base didn't weaken narrow rims as much as a Schrader. They renamed it the Presta.
