Mike N.
So I received my Schwalbe Big Ben Plus 27.5 x 2.15 tires from England yesterday. It was a little cheaper buying them from England with the shipping then purchasing them here. $38.50 each and no tax. I'm sure the Kenda tires are decent but I have had pretty good luck with Schwalbe on my bikes. I already had a rear flat on the Kenda and it was just a little thorn.
The 2.15 size is a little narrower and sits a little lower than the 2.4. You just have to be careful pedaling around corners fast so you don't ground your pedal. I also like the reflective sidewall on the Schwalbe and I'll remove those reflectors they put on the spokes. I have no clue what type of Kendas are on the bike since they do not have a name highlighted like other Kenda tires. Also I'm changing out the Kenda innertubes with Conti MTB tubes. I like the stems because they have that threaded nut that keeps the stem from falling in when you're trying to fill a flat.
One last thing the power cord the goes to the motor. The connector has a threaded ring to screw the two parts together. Nice little add on to make sure you get a secure contact.
All in all very happy with the bike. To reach a certain price point they probably went a little cheap on the tires but easy to remedy.
