spokewrench
- USA
My Radmission became my backup bike 8 months ago, when I bought a new e-bike. I'd ride it several times a month. When hot weather came, I brought the battery indoors so it would stay cooler. That meant I rode the Radmission less.
A few days ago I put in the battery and rode it. The mechanical brakes had always worked very well, but now they were very poor. Braking several times from 20 mph improved their performance, but the pads wore incredibly fast.
I've discovered that automobile pads should be stored between 10 and 25 C and between 40 and 60% humidity. Hotter or damper storage will cause them to soften. Colder or drier storage will make them brittle. I guess a few weeks of high humidity without riding to heat the pads up allowed moisture to soften them. I guess a bike ridden less could wear out pads faster than a bike ridden more.
I've always removed calipers to change pads. I can clean and inspect and, before tightening the mounting screws, adjust and align the calipers with the new pads. On several occasions, I've had spacers repeatedly fall off the screws each time I tried to put the caliper back on. Those spacers are weird to me. The ones on the Tektro Aries have a metal cup over a sort of metal washer. If an assembly falls off I have to figure out the proper reassembly. A dab of silicone RTV can hold them in place.
How do these spacers work? When I remove a caliper, would it be better to install new spacers? Are they available?
