Shimano Linkglide for e bikes.
fooferdoggie
just got the new Shimano Linkglide installed on our tandem. We were wearing Kept wearing out the 13t cog at about 2000 miles as that was our cruising cog. Since we changed the motor from the 20mph to the speed motor I can see even more wear on it and the 11t. Older it let us change the 36t chainring to 38 for a little more high-end room. With an 11-52 range climbing hiss even 20 grades would be much easier now. Shifting to the largest cog on the 18% grade test hill was like what the hell? It was louder than usual. But with practice, it should be better. It is supposed to shift under load better and last longer as the cogs are steel. the chain is supposed to last longer too and it's only like 21.00 for 11-speed.
The shifter is nice with grippers so your fingers don't slide off it after it gets slick after 10,000 miles. You only get 2 shifts on the upshift instead of the usual 3 but I always had trouble getting three as the reach was bad. Two seemed easier too. But no gear display I always look as if I would lose track when coming to a stop as I don't shift as much on the tandem. it also uses a 10-speed hub so no changes there.
Is the Linkglide noticeably better in any aspect than the older Shimano chain/derailleur system? Or, is it just the promised longevity of the drivetrain, Steve?
man, serious climbing ability. Now we can spin up 18 to 20% grades keeping the rpms above 80 or so the more is the most efficient. On hills, we can spin up them or go faster plus with the little larger chainring we got the bike up to 28 mph on a flat peddling at 100 rpms.
Wore out two cogs on our linkglide cassette. The 9th and 10th Ithink after around 4000 miles, though not positive. the price is so high on these, though. They have two versions one for 140.00 that only has the 10th and 11 cogs loose with an aluminum spider and this guy that has the last 4 cogs loose. i was not sure what one I had to I bought this one and forgot if I have the same one I can use the bad cog and replace it and save the cassette as I have the bad cog in the mail. or I had the cheaper one and would need this one since the worn cog was not replaceable.
Yeah, if you can just replace the worn cogs, the savings will add up if they go out in 4000 miles. At least the way you ride. 4000 miles takes me a few years.
on the tandem, we would usually get 2k on the 9th cog when we had the standard 11-42 cassette. I have found the separate cogs on ebay they are only about 12.00 each. but I needed it for this weekend, and i would not get the new one till Monday. I iwll stock up on all the 4 separate ones as you really feel the skip on the tandem. you can shift under load but its pretty clunky on the larger cogs.
The shifter is nice with grippers so your fingers don't slide off it after it gets slick after 10,000 miles. You only get 2 shifts on the upshift instead of the usual 3, but I always had trouble getting three as the reach was bad. Two seemed easier too. For tips or advice, I even looked up electrical repair near me while tinkering with the bike electronics. But no gear display, I always look as if I would lose track when coming to a stop as I don't shift as much on the tandem. It also uses a 10-speed hub, so no changes there.
View attachment 177132View attachment 177133
The Shimano Linkglide upgrade provides more durability with steel cogs and a longer-lasting chain, a wider gear range with the 36t→38t chainring, and easier climbing with the 11-52 setup. Shifting under load may take some practice, but the improved shifter grips and two upshifts make control easier. Overall, it should handle the tandem’s demands better and last longer.
Not sure, but I think we got 1 year or around 4000 miles from the smaller cog, so that’s pretty good. Usually, we got 2000 miles or so out of that cog.
