Problem with the headlight. The headlight started to shine blue
carrera_zol
Europe
The headlight started to glow blue, maybe someone has experienced this and has a solution?
This happened after I changed the language on my Bosch Intuvia from German to English. Is there any way to solve this programmatically?
SUPERNOVA V521s headlight, my Riese & Muller Nevo bike
Ride with it.
I use these lights for twilight rides can be removed easily, I like my handlebars clean. You can remove the lights at will leave the clips on.
That is strange tho was your lights advertised with blue lights options?
My blunt advice, Delete blue lights by going to your ebike dealer and have them replace it to white light.
Does no one have a solution to the problem? Maybe I wrote in the wrong section. Please help me out 🙏
As you appear to want an immediate response, you may have to wait a bit due to different time zones.
It may be worth sending the question to Riese and Müller / Bosch / Supernova.
DG…
Okay
It's not the end of the world.
Just put a USB charged white light on your bike. You can fashion a holder for mini tactical light if you needs to ride nighttime. Or my other option is a headlight that you wear on your forehead.
Only negative on that is some body can shoot the light out and you be dead
You received some good advice on Reddit about this. Verify that you are getting enough power to the light, and the info about phosphor is also a possibility. There were a bunch of led street lights around here that suddenly went blue. It was a defect in the light, so they had to replace the lights. Also, have you tried switching the language back to German to see if that fixes the issue?
Thank you all for your answers!
SuperNova replied that this is their known problem with blue light. They will fix it free of charge even if the headlight is older than 5 years. I will try to send it for warranty repair or replacement.
