harryS
Nothing can happen until you measure the dimensions of the fork, First you have to determine if it is threaded or threadless, Not just a matter of looking at pictures. You have to get the dimensions,
The diameter is the next parameter. It's either 1" or 1-1/8" for both types. For a threaded fork, if you look at the stem that goes to the hand;bars. that will be either 1" or 7/8" for the respective sizes.
Then you have to measure the length of your frame to determine if the candidate fork is long enough. And if it is a threaded fork, if the thread are long enough to extend into your frame,
It looks like you have a threaded fork, and those can be hard to source. They nay often be long enough,. but not have enough threads, Also,with rim brakes it may not be possible to use a 700cc fork if you have a 26" wheel. The calipers may be too short or too long,
Suspension forks are almost always alloy and even weaker than steel forls when it comes to a motor.Your best bet is to have buddy that's a good welder. Find a steel fork and weld the top tube of the old one to it, Weld on taps for disk brakes. Beef up the dropouts by welding the torque arms to them.
