taserface
- USA
I think I could use some help/feedback.
I am currently shopping to upgrade my old BBSHD bike (KHS 680+, 27.5"x3") and currently, the Voyager ULTRA AM1000 V6 and Liberty Ultra CC FAT have worked their way to the top of my list... but while quite different, I'm finding myself toggling back and forth between the two and analysis paralysis is starting to set in...
AM1000 mullet tire config/geometry?
First... the whole mullet tire thing (new to me). The AM1000 offers both mullet (29/27.5) or 27.5 (x2) config. I am assuming the geometry is only optimized for the mullet config: "the wheelset adopts the now more popular 29/27.5” wheelset instead of the previous 27.5/27.5” (per description page). Is that assumption correct or does anyone know if they have mutators in place to allow switching back and forth while maintaining optimal geometry? (or have 2 different frames, depending on wheel setup... doesn't seem likely) Also, does anyone have experience with this bike or a similar mullet setup in an eMTB/MTB? I am wondering how the 29/27.5 mix behaves in non-downhill settings? (flat trails/road, uphill on roads, etc). Any cons?
Aside from the mullet thing, I am trying to figure out which is a better fit for me in general.
My preferences + use cases:
I want a good bike that has good range, good power, that's a good value and can do a little bit of everything (just like everyone else?).
15% of the time: a bit of everything (fun trails in the area (nothing overly technical/aggressive/challenging), cruising around on local streets, etc)
85% of the time: daily (work) commute, ~3x a week:
- I'm a bigger/heavier rider (>180cm, ~110-120 KG w/ gear, but only ~75cm inseam)
- relaxed, comfortable ride (won't be using throttle much, at all, but a lot of "lazy PAS" power)
- ~30 KM each way (a bit under 60 KM round trip). ~20 KM flat/hard maintained trail (but with leaves, some gravel, etc). 10 KM on road (with hills).
- ~200-300 meters change of elevation/hills (on the road sections)
- it rains a lot here
, but snow is not a concern
- I would like to mostly keep the battery between 80% -> 30% and not stress the battery beyond that, if possible. Buying an extra charger and recharging at work is doable (but more range the better and would like to be able to make the trip 'comfortably' on a 90%+ charge without having to recharge at work, if possible).
My initial thinking is that the AM1000 should certainly offer better range. Same battery on both, but a lot more rolling resistance/weight on the CC FAT.
However, I was also thinking that the CC FAT would offer a more comfortable ride and might be a better match for my weight.
...but I don't know how much I am giving up on either side (and don't know what to make of the mullet config for my needs). I think I'm leaning slightly towards the AM1000, since the range difference is easier for me to quantify than the possible differences in comfort/weight handling.
I'm interested in getting some unbiased third party perspectives
, bonus points for anyone who has experience with either setup (mega bonus points for those who have ridden both, but realistically not expecting those to be awarded). I did see the update from @AtlasRearden in the CC Fat thread, but while the bike seems like it could be a good fit for me, the range/efficiency may be a bit shy of what I'm looking for.
Overall, both bikes look great and I'm sure either would "work", but this is a big $$ purchase, so I want to do my due diligence in evaluating the the best one for me. Thanks.
