My son, grandson and his wife live up in Oregon.
Beautiful place but too much rain for me.
What is your throttle issue?
Hello Solar Cabin, from not very rainy Ashland these days !
We live up a 20% grade with a street distance up that grade of ~ 0.5 km in Ashland. My bike won't climb it unless I pedal like hell wth its supplied largest  rear 34 tooth cog. Even then, the motor is near stall : Its not  a situation conducive to its longevity.  I want to upgrade to  40 or even a 42 tooth if possible. ( I am 93 lbs:  My wife is 57kg and her Dost bike for some reason, came with the largest  cog of 36 teeth in the rear cassette== all of which gets her up the grade around Ashland with far less strain on the motor although she cannot rely upon the throttle alone to do this: She has to pedal up it ).
  Beyond the threat to my failing male ego...
  I'm told that the motor has been internally wired by Bfang to limit the throttle to 30Km/hr, even though, with pedal even ghosted, it will go far faster or go up a far greater incline-but  still not a 20% incline of this length.  One cannot apparently change this using the programming cable process as its "hard wired" into the controller.
 Bfang apparently changed this controller in 2017 in reaction to  more stringent regulations for pedal assist to effectively dominate the throttle. Before that Im told, the throttle would not only maintain but override the pedal assist if necessary. I fail to access technical support from Bfang USA because I did not buy a motor from them but maybe someone on this list  knows how to contact them ?
Im seeking a way to change the controller back to its former "throttle-dominant" position but if not will just goto a larger rear cog.  I don't see another solution.
Thanks in advance for your insights,
Mzee Richard
