Thanks.All I know is OneUp makes a variety of excellent dropper posts. You would reuse the existing cable. When my brother was replacing a Giant dropper with OneUp V2, the work looked fairly easy. I am no expert though
@PDoz, could you chime in?
It would be the best to reuse the existing lever and cable as the cable is internally routed inside the frame, and the cable replacement could be an ordeal.You do need to buy a lever unless you reuse you current one. Their $40 lever includes cable and housing which is also reasonably priced.
Thanks. Is it difficult to change dropper but not lever and cable for a old guy with five thumbs?It would be the best to reuse the existing lever and cable as the cable is internally routed inside the frame, and the cable replacement could be an ordeal.
Better leave it to a techie at an LBSThanks. Is it difficult to change dropper but not lever and cable for a old guy with five thumbs?
Thanks.Better leave it to a techie at an LBSMy brother is my private techie, and I was happy it was him to do the swap. It did not look complicated but I would not do it myself.
Let me tell you about the background. My Giant Trance E+ 2 Pro came with a Giant dropper post. (Giant droppers are one of the least expensive in the market but their quality is disputable). That dropper broke very soon. Following the advice from @PDoz, I bought a 150 mm x 30.9 mm V2 dropper from OneUp. My brother looked at these two parts, figured out how it was all working and swapped the droppers in no time. Meaning, any qualified techie would be able to do the same.
Yes I let my LBS do it cus my experience trying to work on my ebikes myself often end up with catastrophic results. The only thing I do myself is changing pads which I do 3-4 times a year due to milage and weather conditions in Norway and of course cleaning and oiling each week.It's not really that hard of a job. Like @Stefan Mikes I swapped out a Giant for a OneUp myself. I also helped my brother install a OneUp in his e-MTB and for that we had to drop the motor to route the cable housing.
You need the correct tools and some patience, but it wasn't really all that hard.
However, having said that, building (and keeping) some rapport with the techs at the LBS is not a bad thing - they do this stuff all the time and stand by their work.
The only thing I change is bike computer batteries and that is not always simple!Thanks.
I always let my LBS service my ebikes.
But I change brake pads myself![]()
My computer battery is still alive so I haven't tried it but it's probably as difficult as a watch battery which I neither need to change since I got a Apple WatchThe only thing I change is bike computer batteries and that is not always simple!![]()
Thanks. I'll check it out.PNW Components as a broad line of droppers and I bought their Loam dropper and had it installed on my hardtail bike. A longer dropper is not going to be a problem but it will not drop down as far into the bike frame which however may be a problem.
Thanks.Technically it is much less difficult to do a swap. The cable housing is already installed on the bike - the cable itself can just be pulled out/through, and replaced with a new cable. With that said, if the lever from the current post is setup and working just fine, then probably no need to replace. If you're not inclined to do it yourself, it would be a quick task for a bike shop to do for you.
You have already got the lever and a routed cable... Why ask for trouble?Thanks.
I have to see what I end up with - with/without cable and/or lever
I thought some droppers couldn't use the lever/cable.You have already got the lever and a routed cable... Why ask for trouble?
