JRA
First of all although I know how to solder and have the right tools but the hardest technique I have run into on my eBikes is shortening the controller to display cable that has many small wires. You really need the right size of strippers first of all and soldering isn't too bad but getting them covered is where I have had problems in the past and usually end up using a liquid tape but it is not very precise and then covering with heat shrink tubing. Basically it is a fussy affair especially it you only solder infrequently.
I had put together a bike for my son that had one of my "jobs" on it and it lost all power. Checking the connections we found a separation in the battery tray under the cover of the pos wire. After soldering it back together and still no power I thought it had shorted out the controller as there is no fuse in between and no readings on the voltmeter to be had. I had a spare controller so we put that on and still no love.
Then I saw the splice I had done which still looked good on the outside but upon cutting the heat shrink off there was a good amount of corrosion in there and one of the wires had parted. I wasn't in much of a soldering mood and so I whipped out my little box of heat shrink solder connectors that I got on impulse but only used a few time previously. It had connectors for the small wires so we cut apart the old "job" and re-stripped the wires and put it all back together with them. It was fast and easy but did end up with a bigger "bulge" however it seems very solid.
So I would have to put my stamp of approval on them in general and they are far better than butt connectors for sure. This is the type of product I have:
