Bicyclista
I wonder whether you all who probably have more experience with mountain e-bikes than I do could help me make a decision between these two Haibike models. Unfortunatley, my LBS does not have demos, in my size, of these two models, so I can't simply ride them and decide.
I am attracted to the 3-inch tires of the AllMtn Plus and to the smooth Bosch motor and proven reliability of the FullSeven RX. Both use 27.5-inch wheels. Being able to ride rough terrain on 3-inch tires would be a plus, and so would be a smooth and reliable motor. Unfortunately, Haibike does not offer a FullSeven with Bosch motor and 3-inch tires!
The AllMtn Plus uses a Yamaha motor, which produces slightly more torque than the Bosch, but is not as smooth (when shifting) as the Bosch, nor does it have as proven a reliability track record as the Bosch. Advantage Bosch.
On the other hand, the FullSeven RX comes with 2.25-inch tires, significantly less wide than the 3-inch tires of the AllMtn Plus. In sand, snow, DG, and loose gravel, advantage AllMtn Plus.
Both bikes are full-suspension, a very attractive quality in e-mountain bikes due to the higher speeds in going over bumps. Haibike has a good system addressing varying chain tension in a rear suspension.
I would give a slight advantage to the quality of components of the FullSeven RX.
The fact that you can jailbreak the Bosch motor is a plus. I don't know if you can jailbreak the Yamaha motor. I'm talking about bypassing the governor (and voiding the warranty) to get motor assist beyond 20 mph.
What would you do?
What would you do?
