Stefan Mikes
Gravel e-biker
- Europe
- City
- Mazovia, PL
Batteries
The Battery #1 (nominally 604 Wh) originally came with my Vado 5.0 made in 2017 (which I bought on November 1st, 2019). It seems that the battery had not been charged before, was "hibernated" and has served me surprisingly well since. I bought a new spare Battery #2 a couple of months later. To my surprise, the "newer" battery has been in worse shape than the first one since the beginning! I also bought a second charger with the spare battery.
Let me describe the status of both batteries as for February 17th, 2022, after approximately 11,000 km (6,836 mi) ridden with both batteries regularly rotated. (The batteries as diagnosed by the BLEvo app).
Battery #1.
The only important data here is the actual battery capacity, which is now 558 Wh. (Neither the number of recharges or "Health" figure can be totally trusted because of historical reasons).
Battery #2. Although that battery was bought later, its full charge is only 502 Wh now!
Note: Mission Control will never tell you the truth: It seems that the Battery Health is always at 100% there!
The bottom line: I totally accept the fact Li-Ion batteries do degrade with intensive use. For me, the batteries are to be used, or I would ride nowhere if I saved them. One has to be aware the batteries will deliver less and less juice over time (and these are not cheap). Now, I own the third "hibernated" battery, and will wake it up when the Spring finally comes here!
Strange behaviour of chargers
When I have charged both batteries fully, I briefly remove the plugs from the batteries' sockets, and then I re-insert the plugs. Surprise! Batteries start charging again! I guess it is about "cell balancing" or so.
Why do I say at least one of the chargers behaves strangely? It is because it never starts balancing of the cells, even if the battery is not at 100%! The charger #1 always helps re-charging the batteries to 100% but the #2 does not!
See the charge of both batteries above. The Battery #1 was recharged with the Charger #1. It offers 552 Wh of 558 available. However, the Battery #2 got only charged to 95%! With its low current capacity of 502 Wh, it only held 476 Wh of the charge! Now, fancy I were to set off for a very long ride with the batteries not fully charged...
As I have identified Chargers #1 and #2, now I always force the Battery #2 to be fully charged with the Charger #1.
Who wants to chime in now?
Battery #1.
