theemartymac
Can an Ultra cause increased drivetrain wear? YUP!
Fair Disclaimer: I am hard on this drivetrain - 300lb rider + cargo, long high-speed commutes with high assist and sport mode, basic chain maintenance of weekly wet lube only.
I received my Rize RX Pro last September, and have been using it primarily to commute to work 45kms round trip. I run at high assist much of the time to keep the travel time reasonable, and tend to use plenty of supplemental throttle on the big hills. I only perform basic chain maintenance and lubing weekly, but do pay regular attention to derailleur alignment - particularly as the new cable stretches in. I'm at 500kms, and 8th cog is now toast and unusable with power. 7th and 9th are still decent, but I have to moderate the power to prevent occasional slippage under high power. The rest of the old cassette is like new. Chain stretch measures comfortably under 50% with the Vernier calipers. Old cassette was a Shimano Alivio 11-34 9 speed.
For comparison, my other bike is a similar Rize X with a 750W hub, and after the 1000+kms I put on it last summer, the drivetrain still looks and measures as new.
The 8th cog - damage likely mostly due to unintentional slippage over the final week or two of use.
Interestingly, aside from the obvious damage from slipping, the visible wear is not overly significant but the cog just progressively lost grip lately under power. 7&9 are getting there quickly, so I have replaced the cassette with a Shimano HG50 11-34, and have a new 49T front sprocket (up from 44T stock) and chain to install tomorrow. Took a couple of rides after just the cassette replacement to verify performance, and it's running like new again even with the old chain. I'm hoping the new front sprocket should do a couple of things; First, get me a bit lower top-end cadence, and second, move the high-use gears down the sprocket a few cogs, so I can use the larger cogs on the hills under power.
I'm not overly concerned with the high wear rate (Expected it, but maybe hoped for ~1000kms), but I'm open to ideas to try out for kicks - other than laying off the gas! lol
I did pick up a programming cable to try and make the drive settings a little more progressive instead of the typical Bafang "all or nothing" power delivery. I'll report back how that goes...
