Hi,
I'm a noivce at ebikes and this is my first post, so please bear with me.
I replaced a front hub 250W motor with a BBS02 500W, but now the battery trips out when throttle is used.
The battery:
36V 10S4P with Samsung 26F batteries 2600msh & 5.2A max draw, all this with a 15A BMS.
So with my limited understanding, I believe that the motor would draw 14A max (500W/36V), which means that the battery should be just within spec?
I've read that the motor may peak to higher load, especially under throttle, and this is probably what's causing the battery pack to shut down.
How can I move forward?
Should I up the BMS to 20A?
or
replace batteries for higher draw items and a bigger BMS 20A or 25A?
or
is there something else I should be looking at?
Cheers
Pav
The battery:
or
or
Cheers
Pav
