Or... this solves the issue that you always complained about Espin with power cutting out once you hit a certain speed.
Think about it, you are in PAS 1 and when you hit 10mph, instead of the power reducing, it auto shifts to PAS 2 to keep you going... and up and up. It's very useful it you're trying to go as fast as possible... esp uphill.
Funny how now this is at the expense of "using more power" but isn't that how power-based systems work?
No, that feature absolutely doesn't solve any problems and works exactly the opposite that I use my PAS most of the time, as I previously explained.  When you start to ascend a hill, a bike slows down, and you need more assistance, not less.  When descending a hill, the bike will speed up, and you don't want the bike increasing the assist level!  That's totally backwards.  I can't imagine a situation where I would want to enable it.  But since it can be disabled, I'm not considering it a negative about the bike, just a useless feature that I would disable.  I haven't seen anyone mention it in the Espin Riders Group.
No, power systems aren't supposed to use more power in situations where you actually need less and want power to be controlled for maximum range as well as a reasonable amount of resistance to pedaling (such as for exercise).  For any dynamically controlled power assist for riding situations, a torque sensor makes more sense, where increased pedal effort increases power output from the motor, such as ascending a hill, so exactly the opposite of the Espin auto PAS.
Also, I've never complained about Espin cutting out power once you hit a certain speed.  I've complained about the OLD PAS on Espin that it regulated the power output to maintain a certain speed like a cruise control, including too strong of acceleration using low PAS.  But, it sounds like the new controller's PAS is greatly improved, so THAT change may solve the cruise control "speed based" assist problem.  Hopefully Al can confirm that is the case without having to workaround it by limiting the current level as was mentioned earlier.  If it's truly power based assist now, kudos for Espin on the change.
It looks like the % adjustment for individual power assist levels is only on certain Espin bikes, like the 2021 Nero and Nesta, which is why it's not found in the config on the Sport and Flow.  Espin doesn't make that clear on their website.  I updated my previous post on that matter:
https://electricbikereview.com/foru...ain-sport-and-flow-on-order.43111/post-430931
If they hadn't raised their prices so much from the $1199 price when I was first looking last year, I would probably be recommending Espin now, based on my understanding of the new controller's PAS.
